Nitron Ntr Fast Road 40Mm Shocks
61 replies to this topic
#1 gertje
gertje
  • 459 posts
Posted 11 April 2015 - 09:13 AM
Last week i fitted the Nitron's. But i have a problem, the riding height is rear 2,5cm higer the oem. When i lower it the springs are loose between the dempers. In front the car can be lower 1,2 mm then the oem riding height. Sorry for my bad english :-)
#2 fezzasus
Posted 11 April 2015 - 09:21 AM
Were they designed for the VX220? The different Elise models have different damper mount points and so have different rear damper heights.
#3 gertje
gertje
  • 459 posts
Posted 11 April 2015 - 11:19 AM
Only elise s1 have a different shocks. Elise s2, exige 340r are all the same Nitron's . I bought them second hand from only had drive 500km (310miles). He was making a race vx220 but it was to expensive so he sold everething. He assurer me that they are the good one I also contact Nitron but it is to fast for a Answer.
Edited by gertje, 11 April 2015 - 11:21 AM.
#4 fezzasus
Posted 11 April 2015 - 12:18 PM
what is the open length of the Nitrons? http://www.vx220.org...-length-issues/
#5 gertje
gertje
  • 459 posts
Posted 11 April 2015 - 12:48 PM
I have see the treat but ther is still no solution?
#6 fezzasus
Posted 11 April 2015 - 01:11 PM
There is a solution, it involves adding a longer eyelet on the suspension. The link was to provide open measurements (395 mm) which might help identifying what's right/wrong with your suspension.
#7 stu8v
stu8v
  • 745 posts
Posted 11 April 2015 - 01:15 PM
Use helper springs to keep the springs seated when on full droop.
#8 gertje
gertje
  • 459 posts
Posted 11 April 2015 - 03:01 PM
http://www.elise-sho...dels-p-135.html You meen this fezzasus. Yesterday i call to this shop the rear was +\- 430
#9 gertje
gertje
  • 459 posts
Posted 11 April 2015 - 03:06 PM
When you use helper springs the i think you be verry fast at the end of the demper (bumpstop)
#10 techieboy
Posted 11 April 2015 - 03:07 PM
http://www.elise-sho...dels-p-135.html You meen this fezzasus. Yesterday i call to this shop the rear was +- 430
No. They won't solve whatever your problem is as the rear mounts aren't replaceable on the VX. Nitron have produced a replacement  part to increase the open length of the dampers, though I'm not sure that is the fix for yours as I've got the 395mm open length NTR's and even at stupidly low ride heights, the springs are not loose let alone at standard ride height.
Are you sure your dampers aren't for a K series engined Elise? Only Toyota engined S2 dampers are compatible with the VX.
#11 gertje
gertje
  • 459 posts
Posted 11 April 2015 - 03:28 PM
The problem is i hot them second hand and they came from under a vx 220. He assured me that the Nitron's are the right one
#12 Exmantaa
Posted 11 April 2015 - 10:42 PM
Gertje; what springs are on those NTR's? And post a few pics
#13 gertje
gertje
  • 459 posts
Posted 12 April 2015 - 07:11 AM
Tomorrow i put the bilstein back, and i post a few pic's on it. I think more and more these are not the good one for the vx
#14 gertje
gertje
  • 459 posts
Posted 12 April 2015 - 07:48 AM
the only pic i have these are the front one.
#15 2-20
2-20
  • 1,317 posts
Posted 12 April 2015 - 08:48 AM
Are you in contact with the bumpstop at the rear ?
Give some détails and pictures.
Give the shocks open lengths, spring rates, etc...
#16 smiley
Posted 12 April 2015 - 08:56 AM
I think you have to tighten the spring to lower the car, not unwind. http://www.sector111...ning_Guide1.pdf
Look at your NTR40's on this car halfway the page http://www.speedster...t=6350&start=15
#17 gertje
gertje
  • 459 posts
Posted 12 April 2015 - 06:28 PM
That's the problem when i put de vx so low like this one i have loose springs. Thighter is higer i think Tomorrow i ame sure of it. This was the car where the Nitron came fromAttached File  ImageUploadedByTapatalk1428863306.320177.jpg   29.83KB   10 downloads
#18 smiley
Posted 12 April 2015 - 06:46 PM
Ronnie was the original owner, who bought the nitrons new.
(before the car crashed, and went to Jim)
http://www.speedster....php?f=3&t=5612
Contact Ron, as aks what spring rates his Nitrons came with.
#19 Exmantaa
Posted 12 April 2015 - 10:57 PM
Just read the last number on the springs for poundage...
(Anything above 500lbs (rear) with the correct longer damper length needs helper springs if you want to ride lowish.)
#20 Paulus H
Paulus H
  • 2,063 posts
Posted 12 April 2015 - 11:39 PM
If you are using such hard springs you will need helper springs. I am guessing you are only using your car on very smooth race tracks? Best regards, Paul
