Posted 29 April 2015 - 12:45 PM
Posted 29 April 2015 - 01:01 PM
dizzy!
Posted 29 April 2015 - 02:46 PM
dizzy!
Too much cylinder pressure for coil pack? Or revs too high for coil pack response?
Posted 29 April 2015 - 03:04 PM
dizzy!
Power capabilities of a dizzy can be higher than a coil pack - would a coil pack larger enough fit in the available space?
Posted 29 April 2015 - 04:10 PM
The dizzy is used by engine management to synchronize the camshaft position with fuel injection[color=rgb(17,17,17);font-family:Raleway, Tahoma, Verdana, Arial, Helvetica, sans-serif;] [/color]plus distribute a 40,000 volt spark. Think the OEM DIS unit is around 30k volts. The ignition system appears to be all MSD Ignition race components.
Posted 29 April 2015 - 04:15 PM
dizzy!
Probably a bit of both. The compression ratio is probably up around the 11's and the rev limiter is probably off the scale The dizzy is good for 12500rpm.
Posted 29 April 2015 - 04:25 PM
Here's the actual ITBs with an optional upper fuel rail. Still listed on Kinsler's website http://www.kinsler.c...php/8-manifolds
Posted 30 April 2015 - 03:12 PM
[font="arial, sans-serif;"]KINSLER FUEL INJECTION[/font][font="arial, sans-serif;"] Date: 01-20-15[/font]
[font="arial, sans-serif;"] 1834 Thunderbird[/font]
[font="arial, sans-serif;"] Troy, Michigan 48084 USA[/font]
[font="arial, sans-serif;"]Page 1 of 2 Tel: (248) 362-1145 [/font]
[font="arial, sans-serif;"] Fax: (248) 362-1032[/font]
[font="arial, sans-serif;"] www.kinsler.com[/font]
[font="arial, sans-serif;"]Kinsler 4 Cyl. Ecotec I.T.B. Manifold For EFI Fuel Metering [/font]
Description Dealer Price
Kinsler 1-piece injection manifold, $2,787.00
[font="arial, sans-serif;"] Basic Manifold Package, [/font]
[font="arial, sans-serif;"]Includes the following: [/font]
[font="wingdings;"]Ø [/font][font="arial, sans-serif;"]Standard throttle sizes: 2 " (51mm), 2 3/16” (55.5mm), 2 1/4" (57.15mm),[/font]
[font="arial, sans-serif;"] 2 3/8" ( 60.2mm), or 2 7/16” ( 61.9mm), 2 ½” (63.5mm), or 2 5/8” (66.7mm).[/font]
[font="wingdings;"]Ø [/font][font="arial, sans-serif;"]Standard bolt location and port location with 100% CNC machined intake ports.[/font]
[font="wingdings;"]Ø [/font][font="arial, sans-serif;"]Ram tube adapters (flat style for straight out ram tubes)[/font]
[font="wingdings;"]Ø [/font][font="arial, sans-serif;"]Aluminum[/font][font="arial, sans-serif;"] or magnesium[/font][font="arial, sans-serif;"]*[/font][font="arial, sans-serif;"] castings[/font]
[font="wingdings;"]Ø [/font][font="arial, sans-serif;"]Bronze throttle shaft bushings installed in manifolds[/font]
[font="wingdings;"]Ø [/font][font="arial, sans-serif;"]Precision ground hard-nickel plated milled style individual transverse throttle shafts[/font]
[font="arial, sans-serif;"] and aluminum throttle plates.[/font]
[font="wingdings;"]Ø [/font][font="arial, sans-serif;"]Throttle arms, throttle stop, safety return spring, stop boss, and billet linkage[/font]
[font="arial, sans-serif;"] connector bar with ball bearings and snap rings.[/font]
[font="wingdings;"]Ø [/font][font="arial, sans-serif;"]Set of (4) Kinsler 180 degree bell aluminum ram tubes: 3” to 9" long.[/font]
[font="arial, sans-serif;"] (Various ram tube diameters can be installed on any throttle bore diameter)[/font]
[font="wingdings;"]Ø [/font][font="arial, sans-serif;"]Vacuum/Boost reference ports, 10-32, 1/16” NPT, or 1/8”NPT thread.[/font]
[font="wingdings;"]Ø [/font][font="arial, sans-serif;"]Bolt-on TPS boss and drive. (Refer to available drive options).[/font]
[font="arial, sans-serif;"]Options:[/font]
[font="arial, sans-serif;"]Idle Air Control rail log kit with flowed and matched orifices for each runner. 370.05[/font]
* Upgrade to Magnesium manifold and ram tube adapters for ~ 33% weight savings. N/C
[font="arial, sans-serif;"]Kinsler K-140 pressure relief valve with AN adapter fittings and vacuum/boost reference. 483.15[/font]
[font="arial, sans-serif;"] This valve is small, lightweight, and purpose built for each pressure range.[/font]
[font="arial, sans-serif;"]Manifold up-grade to billet radius plates (replaces ram tubes and top adapters). 433.80[/font]
[font="arial, sans-serif;"] These are for higher RPM ram tuning and are NOT available for ALL throttle sizes.[/font]
[font="arial, sans-serif;"]Manifold assemblies may vary per application, please call regarding your specific needs.[/font]
[font="arial, sans-serif;"]PRICES SUBJECT TO CHANGE WITHOUT NOTICE ![/font]
[font="arial, sans-serif;"]File: EFI-Ecotec- 4Cyl Manifold-15.doc[/font]
[font="arial, sans-serif;"]Page 2 of 2 Tel: (248) 362-1145 [/font]
[font="arial, sans-serif;"]Upgrade throttle size to “Custom” made 52, 53, or 65mm throttles. 246.45[/font]
[font="arial, sans-serif;"]Upgrade manifold assembly with lower angle throttle plates for “Street and Road Racing” 98.95[/font]
[font="arial, sans-serif;"] applications. Increases throttle control at lighter loads and low throttle angles.[/font]
[font="arial, sans-serif;"] Enhances possible EFI mapping resolution by 5%. [/font]
[font="arial, sans-serif;"]Billet air box plate, 3/8” thick aluminum, 8” x 16.5”, with machined holes for specific 135.70 [/font]
[font="arial, sans-serif;"] throttle bore sizes and bore spacing. Add $ 8.00 for painted plate.[/font]
[font="arial, sans-serif;"]ITG Air filter assemblies are available in various sizes. Price depends on specific size. Est. 227.25[/font]
[font="arial, sans-serif;"] Base plate requires machining to allow the ram tubes to slip through at the proper C-C.[/font]
[font="arial, sans-serif;"]***Labor to custom machine above ITG base plate to fit ITB’s. 94.55 [/font]
[font="arial, sans-serif;"]Economy air filtration “Booty”, Nylon type mesh, fits over ram tube bells. 67.30[/font]
[font="arial, sans-serif;"] Available in various colors. ( Black, Blue, Red, Orange, Lime Green, and Yellow) [/font]
[font="arial, sans-serif;"]We recommend that the following upgrade be utilized for Drag Racing only with [/font]
[font="arial, sans-serif;"] sequential staged injection. [/font][font="arial, sans-serif;"] NOT recommended for street applications.[/font]
[font="arial, sans-serif;"]NOTE: A Plenum manifold is also available. Call for machine/build details. Est. 2,651.00 [/font]
[font="arial, sans-serif;"]--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------[/font]
Posted 30 April 2015 - 04:20 PM
Jesus, peanut prices for monsterous power.
Posted 30 April 2015 - 08:33 PM
Posted 30 April 2015 - 09:29 PM
Cheap, but with such an old fuel and ignition system there really isn't any complexity to justify a higher cost.
Posted 30 April 2015 - 09:41 PM
But you can run whatever ignition you want and deliver the fuel to the injectors anyway you want...Cheap, but with such an old fuel and ignition system there really isn't any complexity to justify a higher cost.
Posted 30 April 2015 - 10:52 PM
Kinsler can even muster up a version that uses mechanical fuel injection. That would require some tlc but fun to work on... no computers!
http://www.hotrod.co...fuel-injection/
Edited by speedster, 30 April 2015 - 10:53 PM.
Posted 01 May 2015 - 02:04 PM
Edited by speedster, 01 May 2015 - 02:09 PM.
