Garage Parts Clear Out
49 replies to this topic
#1 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 03 May 2015 - 06:30 PM
Right I'm having a clear out of vx parts I've built up over the years.
Air Filter intake pipe, used with marks £12 delivered
Engine cover, few marks but generally not to bad condition £70 not sure how much to post but it's possible.
Front bonnet cover. Few marks but generally not to bad. £50 not sure how much to post but it's possible.
Oem turbo spoiler in black, few marks on it but generally not to bad £105 delivered
Roll over bar cover, few marks and rubber seal needs needs sticking back down again. Doesn't come with the brake light or shark fin aerial £45 delivered
I have a Exige spoiler that might be a interest to you guys that I was going to fit to the vx but change of plan. There's a picture of one fitted to a vx and it don't look that bad. Not to bad condition but could do with a respray £130 delivered
Vx220 outdoor car cover from cover zone. Has a couple of rips and holes in it and marks here and there. £15 delivered
Steering column Oem. Few marks but not to bad. Would be perfect if you wanted to get it re trimmed. £20 delivered
Silicone pipe £7 delivered
2.9 inch pulley for m62 £30 delivered
http://i1174.photobu...zpstiix6evk.jpg
Standard stereo that came with the vx. It's works from what I can remember but the black trim thing has broke but doesn't effect how it works and you can't see it once fitted. £15 delivered
http://i1174.photobu...zpstdoq55np.jpg
Front Oem anti roll bar £30 delivered
http://i1174.photobu...zps9wrji2nx.jpg
Badass engine covers. They have marks and scratches ect. £8 delivered
http://i1174.photobu...zps0hdiylga.jpg
Oem manifold £30 delivered
http://i1174.photobu...zpsb6hgiyki.jpg
Centre tunnel. scratches and marks £15 delivered
http://i1174.photobu...zpswemtlzso.jpg
Oem radiator houses £30 delivered
http://i1174.photobu...zpsbqmpgldo.jpg
Seat belt covers. Scratches and marks £15 delivered
http://i1174.photobu...zpsknw0j3dk.jpg
Oem fuel rail £25 delivered
http://i1174.photobu...zpsvt472h92.jpg
Oem head covers. One is cracked but you can't really see this once there fitted. Perfect to get them re trimmed and cut down if your tall and banging your head. £45 delivered
http://i1174.photobu...zpsicqeveqo.jpg
http://i1174.photobu...zpsxnuseqhx.jpg
Oem gear knob. Scratches and marks. £15 delivered
http://i1174.photobu...zpssvru6rtg.jpg
Rear brake light. One broken lug. £20 delivered
http://i1174.photobu...zpsijos8k8m.jpg
Vx wheel badges, rear badge and engine cover badge. All used with marks £20 delivered
http://i1174.photobu...zpspoizrg19.jpg
Momo gear knob screws straight onto the vx gear shaft. Well used. £12 delivered
http://i1174.photobu...zps00ek3jlr.jpg
Vx Oem aerial. Seal is perished a little. £15 delivered
http://i1174.photobu...zpskyu0sav8.jpg
Erg valve. Was working fine when it was fitted to my car. £15 delivered
http://i1174.photobu...zpscbhy3nm9.jpg
Custom rear clam exhaust mesh lip. The bit that falls off normally. This has been cut and bent to the right shape so just needs painting and glueing on. £12 delivered
http://i1174.photobu...zpslfynd7ab.jpg
Speedo metal trim that fits the vx speedo. I was going to cover it carbon fibre vinyl to hide the elise cutout.. £15 delivered
http://i1174.photobu...zpshnyxr6sq.jpg
Gaz golds springs. Think one set was 450 and the other was 375 maybe. Not 100 percent tho. £30 delivered
http://i1174.photobu...zpsteszlvtv.jpg
Standard bilstein suspension. £100 delivered
http://i1174.photobu...zpsrtw09rk7.jpg
Oem toe links. £20 delivered
http://i1174.photobu...zpsaj9dhr1z.jpg
Halfords car cover. Fits the vx. Few marks and one slight rip if I remember correct. £30 delivered
http://i1174.photobu...zps9ctcow5j.jpg
Speedo cover. Cracked at the top. Perfect for a retrim. £15 delivered.
Brand new vxr fuel rail. £40 delivered
http://i1174.photobu...zpsc9jdumgq.jpg
Turbo Oem water ingress kit £30 delivered
http://i1174.photobu...zpsfjvjvgk4.jpg
Vx220 gm upgraded speaker kit. They work fine. Few marks on the covers and the badges have fell off the covers. £25 delivered
http://i1174.photobu...zpsougqgfpf.jpg
Standard vx speakers £7 delivered
http://i1174.photobu...zps9t1wwgt6.jpg
Wiper stalk £3 delivered
http://i1174.photobu...zpsk8hwjr9f.jpg
Vx sills extensions. Someone made these up a while ago and they bolt to the sills. There's a picture somewhere of them fitted. £30 delivered
http://i1174.photobu...zpsdrrxrp5y.jpg
Kenwood kvt 627 DVD/CD player. This one fits the vx perfect and no need of the dash to be cut for the 7 inch screen to pop out. The only problem is the attachable panel is a little faulty and it bounces around when the car is moving and keeps switching on and off. Was working fine when it was fitted to my car until it developed this fault. Another panel could be bought from eBay or maybe a easy fix for someone. Sat nav and iPod connections can be bought for this head unit.selling cheap at £50 delivered as I can't be bothered with it now.
http://i1174.photobu...zpsznvufgn1.jpg
Oem Centre console leather surround. £15 delivered
http://i1174.photobu...zpstrmct6dc.jpg
Vx Oem leather door shoulder pads. In good condition. £40 delivered.
http://i1174.photobu...zpsmj3f8wpb.jpg
Box of used ball joints and bushes. Came off my car at 29,000 miles. £22 delivered
http://i1174.photobu...zpsyujvroij.jpg
Ecu with stage 3 software on it. £50 delivered
http://i1174.photobu...zps6izhhyzm.jpg
Box of used Pistons, springs ect. Came off my car at 29,000 miles. £17 delivered.
http://i1174.photobu...zpsftw1iytu.jpg
Vx N/A rear clam foam mat. £30 delivered
http://i1174.photobu...zpstcz0hrki.jpg
Standard N/A rear diffuser. Marks and scratches ect. £20 delivered.
http://i1174.photobu...zps1ehxnfjj.jpg
#2 Renny
Renny
  • 1,171 posts
Posted 03 May 2015 - 06:37 PM
Can I take the sill extensions? Will pm later. Thank you
#3 myles
myles
    Sausagefest
  • 2,093 posts
Posted 03 May 2015 - 06:40 PM
I'll take the cover please. PM sent.
#4 Chris SCVX
Chris SCVX
  • 134 posts
Posted 03 May 2015 - 06:49 PM
Can I have dibs on the badass engins cover bits and box of Pistons bits please will pm you in the next hour or so for payment details.
#5 phippsy
phippsy
  • 472 posts
Posted 03 May 2015 - 07:03 PM
ill take the the turbo spoiler please if its available
#6 Bojang
Bojang
  • 88 posts
Posted 03 May 2015 - 07:04 PM
I would like the exhaust mesh lip please
#7 Elliot_holder
Elliot_holder
  • 73 posts
If not gone already. Can I take the vx220 specific car cover (if already gone can I dibs the halfords one).
#8 phippsy
phippsy
  • 472 posts
Posted 03 May 2015 - 07:10 PM
And ill take the suspension please. Will be useful while I send mine off for a refurb.
#9 Elliot_holder
Elliot_holder
  • 73 posts
Posted 03 May 2015 - 07:16 PM
Can I take the kenwood headunit too please?
#10 Nelly Vx
Nelly Vx
    3/3 Of a Queen
  • 5,928 posts
Posted 03 May 2015 - 07:54 PM
Center console for me please Luke :thumbsup:
#11 JdoubleU
JdoubleU
  • 71 posts
Posted 03 May 2015 - 08:10 PM
I'll take the gear knob please. Pm sent cheers John
#12 fiveoclock
fiveoclock
  • 9,453 posts
Posted 03 May 2015 - 08:31 PM
PM'd difusser
#13 phippsy
phippsy
  • 472 posts
Posted 03 May 2015 - 09:03 PM
PM'd spoiler and shocks
#14 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 03 May 2015 - 09:10 PM
Luke I might be interested in the Exige spoiler if it's still available - let me know
Edited by Graeme Lambert, 03 May 2015 - 09:10 PM.
#15 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 03 May 2015 - 09:28 PM
l will sort through the all the messages and replies tomorrow after work and let people know what stuff is left and gone. Il hopefully get them packaged and sent out before the weekend to everyone so bare with me if that's ok, as it will take time with work ect to get everything sent.
#16 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 03 May 2015 - 10:53 PM
Il do it now instead lol. Tubby spoiler SOLD PENDING PAYMENT Oem shocks SOLD PENDING PAYMENT Fitted car cover SOLD Standard stereo SOLD PENDING PAYMENT Ecu SOLD PENDING PAYMENT Badass engine cover SOLD PENDING PAYMENT Box of Pistions SOLD PENDING PAYMENT Forward Center console SOLD PENDING PAYMENT Halfords car cover SOLD PENDING PAYMENT Kenwood CD player SOLD PENDING PAYMENT Sill extensions SOLD PENDING PAYMENT Leather gear surround SOLD PENDING PAYMENT Standard diffuser SOLD
Edited by haggi961, 03 May 2015 - 10:57 PM.
#17 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 03 May 2015 - 10:56 PM
Just realised your from Germany so postage will be more I would of thought but can still find out if your interested?
#18 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 04 May 2015 - 04:46 PM
Suspension still available Forward Center console still available Tubby spoiler SOLD Fitted car cover SOLD Standard stereo SOLD Ecu SOLD Badass engine cover SOLD Box of Pistions SOLD Kenwood CD player SOLD Sill extensions SOLD Leather gear surround SOLD PENDING PAYMENT Standard diffuser SOLD Oem gear knob SOLD
#19 Wolfstone
Wolfstone
  • 12,987 posts
Posted 05 May 2015 - 07:15 PM
Think it might be MartinS' car that has them.  Here's a couple of pics of his car.
#20 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 05 May 2015 - 08:00 PM
That's the one. They look really good fitted if I must admit myself.
