Speedometer Stuck At Max Speed When Turning On Ignition
speedometer
6 replies to this topic
#1 Mozen
Mozen
  • 120 posts
  • Interests:Cars, music, photo etc.
Posted 11 May 2015 - 09:43 AM
My speedometer goes to max speed when turning on ignition and stays there until I turn off the ignition at which time the needle goes back to null.
This of course means that it does not show correct speed.
My car is a VX220 Turbo 2005 with only 12000 miles on it. When driving I can see that once I have picked up some speed and then go slower the needle goes back down accordingly and then back upwards when I then increase speed again.
For me this indicates that the sensor in the left back wheel gives correct speed signal at speed.
I have tried to do the speedometer instrument reset
1. Unlock car
2. open door
3. press and hold odometer reset button.
4. turn on ignition while still holding the odometer reset button.
I can see that the instrument reset and I can read the version of it. This however does not solve my problem.
I have read that problems with the speedometer can be a shortcut by the wires in the transmission tunnel but in my mind then it would not give indication upwards and downwards at speed.
Can it be a problem with the soldering in the instrument or a connector which is loose behind it?
Have anyone else had the same problem and how did you solve it?
#2 Cookies220
Cookies220
  • 2,721 posts
Posted 11 May 2015 - 11:30 AM
First place I would look is at the wiring at the sensor on the hub.  Perhaps the wiring is a little corroded or loose and that's why you're getting false readings.
#3 techieboy
Posted 11 May 2015 - 11:35 AM
Remove fuse 7 or 8 (whichever it is that supplies the ECU) or disconnect the battery for 10 minutes and see if that resets it.
#4 smiley
smiley
    Thetan level 15
  • 10,427 posts
Posted 11 May 2015 - 12:27 PM
8
#5 Exmantaa
  • 3,982 posts
Posted 11 May 2015 - 12:38 PM
You can simply disconnect the ABS connector to see if your problem is coming from the ABS/Wheel speed sensor shortcut. (althought that should give you an ABS error light...)
#6 Mozen
Mozen
  • 120 posts
Posted 21 May 2015 - 07:58 AM
Thanks for all ideas! I can allways turn off any error lights with the OBDII scanner so it is worth a try.
I have not found time to investigate further (three small kids) but will write what I find if anyone else have the same issues.
#7 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 21 May 2015 - 08:08 AM
Don't think you can turn off any errors on abs or airbags with a normal scanner ? Need op com to get int those systems
Also tagged with one or more of these keywords: speedometer
