Front/rear Engine Mount Replacement
18 replies to this topic
#1 Horace
Horace
  • 1,290 posts
Posted 03 June 2015 - 12:15 PM
My side engine mounts need replacing.  The front/rears have never been replaced (95k on car).  Is it prudent to replace the front/rears at this mileage anyway, or do they last forever?
I don't want poly bushes etc., just standard replacement.
#2 slindborg
Posted 03 June 2015 - 12:19 PM
its probably wise to if they are cheap enough... but probably not vital if you aren't doing lots of emergency starts
#3 GFWilliams
GFWilliams
  • 356 posts
Posted 03 June 2015 - 01:16 PM
Poly bushes were lovely on my car, transformed it. Don't make it vibrate too much...
#4 Horace
Horace
  • 1,290 posts
Posted 03 June 2015 - 03:04 PM
Really?  Qualify 'too much'?  This is my daily drive.  I sit in traffic alot.  I don't want new teeth.  I rarely do emergency starts  :happy:
#5 Zuber
Zuber
  • 1,429 posts
  • Interests:Finding a way to motivate myself to get fit. Anything Interesting.
Posted 03 June 2015 - 05:30 PM
Got them in mine. Initially, they did vibrate quite a bit. Annoyingly so. But settled down fairly quickly...
#6 YawningHippo
YawningHippo
  • 112 posts
Posted 03 June 2015 - 05:34 PM
I have had them fitted and at low revs, ie pulling away using less than 2k revs it does vibrate a bit. They have only been in for about 30 miles so far though!
#7 scw02102
scw02102
  • 1,581 posts
Posted 03 June 2015 - 09:56 PM
If u fit two front and back it does vibrate a bit under 2k But u can just fit 1 it's less noticeable
#8 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 03 June 2015 - 10:44 PM
I maybe blind, but on my SC 2.2, I cant see the front engine to get the poly inserts fitted. Am I missing something?
#9 Steve.i.am
Steve.i.am
  • 990 posts
  • Interests:Bends
Posted 04 June 2015 - 07:51 AM
Front engine? The engine is in the back. Anyway, take undertray off, get underneath and you can't miss it.
#10 siztenboots
Posted 04 June 2015 - 07:56 AM
in retrospect having fitted vibratechnics, I would not. Stick with the OEM ones.
#11 PaulCP
PaulCP
  • 6,066 posts
Posted 04 June 2015 - 08:16 AM
Steve, can you elaborate on why? Do you have the road or race spec ones?
#12 Horace
Horace
  • 1,290 posts
Posted 04 June 2015 - 09:19 AM
Given that there is no consensus on this one, think I'll play it safe and stick to OEM.  I've fitted the side mounts before no problem.  Are the front/rear mounts an easy replace?
#13 siztenboots
Posted 04 June 2015 - 09:26 AM
I now get noticeable gearbox chatter when coasting , road spec afaik I could try swap back just the gearbox side to oem to verify
#14 scw02102
scw02102
  • 1,581 posts
Posted 04 June 2015 - 06:00 PM
front and rear are easier to change than the sides just long treads
#15 Horace
Horace
  • 1,290 posts
Posted 04 June 2015 - 06:31 PM
Hi All,
Can't seem to find a sticky for the front/rear mount replacement.  Does anyone have a guide?  Ta.
If I buy these,
http://www.autovaux....dster-opel.aspx
are they just a quick straight swap, or do I have to press them out/in?  Ta.
#16 Steve.i.am
Steve.i.am
  • 990 posts
  • Interests:Bends
Posted 04 June 2015 - 07:03 PM
They fit into their carrier bracket like so..
Not sure if that is a tight interference fit or what?
If it were me I'd leave them alone as failures seem ultra rare - just replace in rare event any fail.
#17 scw02102
scw02102
  • 1,581 posts
Posted 04 June 2015 - 07:19 PM
sod getting that out and new one in Most fail just buy the inserts that squeeze in the gap so easy as its push fit
#18 Horace
Horace
  • 1,290 posts
Posted 04 June 2015 - 07:40 PM
But I don't want poly inserts, as I want a pleasant cabin experience
#19 slindborg
Posted 04 June 2015 - 07:43 PM
Same as Astra mounts, might be able to get them pre fitted and swap the whole assembly over There isn't a guide as they aren't common and no one has bothered lol I'll see if I still have the spare metalwork for one mount in the mancave
