Ball Joint Removal
Posted 04 June 2015 - 08:43 PM
Posted 04 June 2015 - 09:23 PM
Posted 04 June 2015 - 09:28 PM
Posted 04 June 2015 - 09:46 PM
Posted 05 June 2015 - 06:55 AM
It is a bit of a knack - I put grease over the rubber gaiter to help - you also need to adjust the steering in order to get the correct angle and you need to approach from the correct side. Then you hammer the fork into place. Use penetrating oil on the thread of the old ball joint and allow it plenty of time to work before you start - if you are changing really old ball joints, that could be the difference between a reasonably easy job and an angle grinder nightmare.
Posted 05 June 2015 - 06:58 AM
What part are you having problems with? The splitting of the hub and wishbone?
I'm guessing you're using this http://www.elisepart...d-removal-tool/
You don't want the elise parts tool for this job, it's crap. You just want a simple ball joint splitter. This one works a treat https://www.machinem... joint splitter
Edited by Gedi, 05 June 2015 - 07:00 AM.
Posted 05 June 2015 - 07:05 AM
BJ's will split with one or several sharp hammer taps to the side of the component they are fitted to. You don't need a splitter.
Posted 05 June 2015 - 07:29 AM
that worked for me too.
Posted 05 June 2015 - 05:36 PM
Posted 05 June 2015 - 08:44 PM
