thought you SC guys might want to know
At Courtenay's rolling road
http://z22se.co.uk/t...d.24909/page-59
Posted 10 June 2015 - 07:27 AM
Posted 10 June 2015 - 07:31 AM
Posted 10 June 2015 - 07:32 AM
What was the full engine, injector etc etc setup on that?
Martin S
Posted 10 June 2015 - 07:38 AM
That's running OBD tuner IIRC. The packaging on the Astra will have certainly helped fit that massive bore manifold too.
Edited by fezzasus, 10 June 2015 - 07:41 AM.
Posted 10 June 2015 - 07:44 AM
Posted 10 June 2015 - 08:25 AM
Posted 10 June 2015 - 08:48 AM
That's my bedtime reading taken care of...
Vocky, when are you building me that 2.5L engine Im after?
Posted 10 June 2015 - 10:18 AM
the power comes from decent ignition timing , the fueling is target lambda ~0.85
interesting the 7200 rpm limit is back , I know the iTBs engines avoid it running standalone webcon
Posted 10 June 2015 - 10:25 AM
Posted 10 June 2015 - 10:30 AM
is it one of the Neo-bros crate engines, ie. out the box 2.0l b207
for high rpm its got a much better stroke and conrod ratio
L61 94.6mm 141mm 1.5:1 LSJ 86mm 144.84mm 1.68:1
Posted 10 June 2015 - 11:03 AM
Posted 10 June 2015 - 11:09 AM
would give more space for the exh manifold
Posted 10 June 2015 - 11:14 AM
It started life as a crate engineis it one of the Neo-bros crate engines, ie. out the box 2.0l b207 for high rpm its got a much better stroke and conrod ratio L61 94.6mm 141mm 1.5:1 LSJ 86mm 144.84mm 1.68:1
Posted 10 June 2015 - 12:28 PM
Any pulley smaller than a 2.9"you will have to machine the snout on the M62 charger.Bloody good numbers those, but must be a chuffing small pulley on there and well and truly out of it's efficiency zone once he's above cruising speeds. Will be interesting to see how he fares intake temp wise outside of isolated dyno runs though at least he's got the benefit of the charger and manifold being in some form of air flow, unlike us with it stuck in no mans land. Bet it screams like a banshee too.
Posted 10 June 2015 - 12:37 PM
Posted 10 June 2015 - 12:43 PM
Mines a 2.9 it does squeal lolI think it's pulleys smaller than 2.8". I can't stand the noise mine makes with a 2.9" on, so God knows how bad it is with even smaller pulleys.
Posted 10 June 2015 - 12:52 PM
Prob no where near as bad as he has a car made from metal and real sound deadening
So accounting for a rough power consumption of 10% for the SC unit, this engine / M62 is flowing ~370bhp.. Seems a lot..
Posted 10 June 2015 - 12:56 PM
are the losses alread factored in during the run down test on the dyno
Posted 10 June 2015 - 01:57 PM
[color=rgb(20,20,20);font-family:'PT Sans', Arial, sans-serif;background-color:rgb(252,252,255);]8.9:1 lower cr more air and fuel in more power works better on a turbo but gains more at higher rpm on the charger [/color]
[color=rgb(20,20,20);font-family:'PT Sans', Arial, sans-serif;background-color:rgb(252,252,255);]still on the 2.8 but will see what happens soon [/color]
[color=rgb(20,20,20);font-family:'PT Sans', Arial, sans-serif;background-color:rgb(252,252,255);]ive got a vid of a pull now gave it some stick its now got a dump valve [/color][color=rgb(20,20,20);font-family:'PT Sans', Arial, sans-serif;background-color:rgb(252,252,255);] not sure how but it pusshtts on gear change lol[/color]
Posted 10 June 2015 - 04:35 PM
2.2 with, supertech double valve springs, +1mm valves, a heavily ported cylinder head, zzp stage 2 cams, electric water pump, balancer chain removed and a decent 3" system
Plus LSJ coilpacks
He has spent many long hours to create his engine and the results speak for themselves
Edited by vocky, 10 June 2015 - 04:38 PM.
