Recommended Torque Values
Posted 11 June 2015 - 08:58 AM
Posted 11 June 2015 - 09:53 AM
dpm
Posted 12 June 2015 - 09:56 AM
Posted 12 June 2015 - 11:09 AM
turbo plugs have crush washers , the aim is to get a good seal , so hand tight if using a ratchet drive is probably tight , but not FT
Posted 02 July 2015 - 06:37 PM
"Wheel bearing assembly[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;] [/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]bolt 210 " I doubt[/color]
Posted 02 June 2016 - 07:43 AM
http://wiki.seloc.or..._wheel_bearings
Using a torque wrench do up the bolts in a circular pattern until they are all tightened to 90Nm
So if it is a M16 bolt
Use a torque wrench to tighten the M16 nut to 220Nm
Posted 08 August 2016 - 08:54 PM
Thanks very much. Great Post
Posted 12 January 2017 - 06:49 PM
Posted 14 January 2017 - 07:00 PM
Subframe to chassis bolts - Not sure if some earlier cars had M10 Bolts - All the cars i have seen have M12's ! 45nm for m12 would be to low and not provide sufficient stretch to hold the bolt in place these should be 86nm - See extract from lotus elise manual below
Fitting rear subframe When bolting the subframe at each side to the chassis rail rear flange, ensure that the anti-corrosion shim plate is interposed. The lower fixing bolts should be inserted from the rear, using a washer and Nyloc nut inside the chassis extrusion. Apply Permabond A130 (A912E7033V) to the threads of the upper bolts before fitting from the front into the weldnuts in the subframe. Tighten all four bolts to 86 Nm. Continue re-assembly in reverse order to disassembly.
Posted 03 March 2017 - 09:57 PM
Evening.
Can anyone clarify what the torque settings are for the 4 bolts in each chassis mounted rear lower wishbone bracket (and front gearbox mount... I assume they're the same?).
IMG_8828 (1).jpg 7.04KB
20 downloads
Posted 05 March 2017 - 02:14 PM
Evening. Can anyone clarify what the torque settings are for the 4 bolts in each chassis mounted rear lower wishbone bracket (and front gearbox mount... I assume they're the same?). Definately not the same !!. wishbone mount bolts are m10 as opposed to m8 for the engine/gearbox mount Bolts are 8.8 metric course so If it's not listed anywhere I usually work to 45nm for m10 and 25nm for m8 IMG_8828 (1).jpg
Posted 06 March 2017 - 02:37 PM
You're absolutely correct (sent an email to Lotus Tech before you replied, and they've just got back to me).
Thanks!
Bing (1)
