Astra Vxr Disks On Vx220?
9 replies to this topic
#1 CraigyT
CraigyT
  • 119 posts
  • Interests:Track driving.
Posted 20 June 2015 - 10:49 PM
Hi all, just wondering if anyone has installed 320mm front disks from an astra vxr to the front of their vx and spaced out the caliper to suit? Any reason it can't be done? I know the vectra/saab 308mm upgrade is popular with 10mm caliper spacers and it was what I was going to do but thought why not go bigger if possible. My car is purely a track car and i can't stretch to the 4 pot upgrades just yet so thought I'd try a less expensive upgrade. Thanks.
#2 RabnaKS
RabnaKS
    If anyone can talk Bllx, I can!💣
  • 2,717 posts
  • Interests:MTB, VX220, oh & cars, golf, sarcasm with humour!
Posted 21 June 2015 - 01:05 AM
Will you have to make sure you have the correct wheel size to make room for the Caliper?
#3 chris_uk
Posted 21 June 2015 - 03:09 AM
yes, i used 330mm discks on my car for a time.. aslong as you have 17's at the front you should be ok.
here is mine.
#4 Nev
Posted 21 June 2015 - 06:17 AM
I recently discovered that the Alfa 159 discs (330mm diam) fit the hub, so have used these in my front brake conversion. You can buy these discs for just £15 !!! Some machining/bracketery would be required to offset the calipers. Have a look at my project thread if you are interested. Good lick.
Edited by Nev, 21 June 2015 - 06:17 AM.
#5 CraigyT
CraigyT
  • 119 posts
Posted 21 June 2015 - 09:20 AM
Thanks for the replies guys, I have a few sets of 17's so will give it a shot. The vxr disks are same height and center bore as the 220, so should only need to space the caliper out radially I guess.
#6 techieboy
Posted 21 June 2015 - 03:15 PM
You might find you're only using two thirds of the pads on a disk that size as they may overlap the edge of the disk due to how far the caliper needs spacing.
#7 slindborg
Posted 21 June 2015 - 07:47 PM
This. The oem calipers will be specced for a 270-290ish mm diameter disc. When I fitted the 308 discs the pads were missing the disc by a couple of mm at the apex, great for keeping the lip off but not great for actual friction material to take the heat and longevity. IMHO you'd want differen calipers for the bigger discs over 308mm
#8 CraigyT
CraigyT
  • 119 posts
Posted 21 June 2015 - 09:12 PM
Never thought on it that way before, Might not be such a great idea without changing caliper after all. Thanks for the input!
#9 SteveA
SteveA
  • 9,158 posts
Posted 22 June 2015 - 08:26 PM
What benefit do you expect from the bigger disks?
#10 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 23 June 2015 - 11:22 AM
Not only that, but I am sure with enough use you would end up with the reverse lip... Where the disc has eaten into the pad and that would have a disc shaped lip on each corner.
