Advise On Suspension For Vxt
17 replies to this topic
#1 SAD73
SAD73
  • 18 posts
Posted 28 June 2015 - 12:39 PM
Sorry guys but after a little help on what I should do, I have a vxt and want to upgrade the suspension , I don't think I will ever do a track day more just fast road, but what can you recommend and is there anything else I should do at the same time if I am going to change it. Ps who is it worth taking it to, to get this work done and set up, I don't mind travelling Thanks
#2 Nev
Posted 28 June 2015 - 02:10 PM
You need to decide what sort of road surface you want to "tune" to IMO. The OEM setup is ace for B-road bashing, saps up most road surface defects well. I'd only think about increasing springs + bounce rates if you want to drive on smoother surfaces and maybe higher speeds. What is it that makes you want to change what you have already? If your shocks, springs, joints are still original, then maybe a refurb of them all would regain a nice tight car. It's easy to get caught up in the "more is better" that is sold to us by the automotive marketing wheels. However several very clever people set the VX220 up to handle (admittedly as a middle ground compromise) for road driving. Changing from the OEM setup needs to be done with a clear purpose in mind IMO, with awareness of both the pros and cons.
Edited by Nev, 28 June 2015 - 02:15 PM.
#3 vocky
Posted 28 June 2015 - 02:26 PM
Sachs are very good for road usage, but you can also get Nitrons or Quantums non adjustables. Try and avoid the cheaper end of the market, you get what you pay for.
#4 SAD73
SAD73
  • 18 posts
Posted 28 June 2015 - 03:57 PM
The front shocks are leaking a little, and I was not sure weather to move to a different type, fast road is mainly what I will be using the car for. Never been really happy with it but if refurb would help then that might be a good idea but looking at the price to do that I could change to after market one so very unsure what to do
#5 chappers2000
chappers2000
  • 489 posts
  • Interests:Sports cars; kit cars, mountain biking
Posted 28 June 2015 - 04:06 PM
Why not just get some new turbo shocks from lotus motorsport auctions. £130 +vat for a pair of new turbo shocks. Need to reuse you springs or buy new Eibach springs. Just bought the front and rear springs and dampers for my NA as the standard suspension is fine for my road use and I have no intention of lowering or going 16" front wheels.
#6 export001
export001
  • 116 posts
  • Interests:If you call constantly breaking the vx then yes
Posted 28 June 2015 - 04:21 PM
Are springs and shocks different between turbos and n/a?
#7 SAD73
SAD73
  • 18 posts
Posted 28 June 2015 - 04:26 PM
Where did you get your springs and dampers from ???
#8 smiley
Posted 28 June 2015 - 04:27 PM
The springs certainly, due to the turdo's extra weight.
With all your interrest in NA versus turdo parts, feel free to have a browse through the parts catalogue
Z22SE is NA, and Z20LET is turdo.
http://www.speedster.../epc/index.html
#9 export001
export001
  • 116 posts
Posted 28 June 2015 - 04:29 PM
Thank you very much mate, things like that I need to consider with my project idea
#10 SAD73
SAD73
  • 18 posts
Posted 28 June 2015 - 06:53 PM
Very useful
#11 siztenboots
Posted 29 June 2015 - 07:01 AM
fitting it is very easy , two bolts each corner
#12 Pidgeon
Pidgeon
  • 5,254 posts
Posted 29 June 2015 - 07:37 AM
If there's better than standard, I'm yet to try them.  There's enough damping to prevent wallow over undulations, but enough movement to swallow most imperfections.  The spring rates are stiff enough to prevent any bottoming but soft enough to allow you to move the weight around the car.
Lotus' R+D dept isn't world regarded for nothing, as neither are Bilstein's standard fit on Porsche RS because they're cheap.
I'm buying a new set.  I don't think we'll be able to obtain new springs (other than through Vx) as they're not a standard ID
#13 denno
denno
  • 1,528 posts
Posted 29 June 2015 - 04:57 PM
I quite like the standard bilsteins for the road, just a shame there isn't any springs to fit that would lower the car a touch, or at least there wasn't the last time I searched.
#14 Pidgeon
Pidgeon
  • 5,254 posts
Posted 29 June 2015 - 06:00 PM
1, Move the spring seat - if there aren't alternative grooves already cut, have some machined in
2, Take a hacksaw to your springs
3, Faulkner (and probably others) will wind you any spring you want.
#15 SAD73
SAD73
  • 18 posts
Posted 02 July 2015 - 06:48 PM
Can you get new springs for these still
#16 chappers2000
chappers2000
  • 489 posts
Posted 02 July 2015 - 08:49 PM
See the lotus motorsport auctions thread in the discussion forum or here http://www.motorspor...=home&store=710 Need to buy springs separate for the tubby dampers.
#17 Hammy of hamhouse
Hammy of hamhouse
  • 205 posts
  • Interests:Cars Hifi. Ex Westfield owner.
Posted 06 July 2015 - 05:06 PM
Having a professional geo setup Might be a worthwhile upgrade ?
#18 Wolfstone
Wolfstone
  • 12,987 posts
Posted 07 July 2015 - 05:31 PM
Brand new rear Bilsteins for a Turbo at £156 per pair delivered:
http://www.motorspor...0&listing=34382
Brand new front Bilsteins for a Turbo at £156 per pair delivered:
http://www.motorspor...0&listing=34370
Cheap as chips (about half the RRP).  Source some new springs or reuse your old ones and Bob's your uncle.
