That sounds about right.... I do recall the Caterpillar brand being mentioned.
Na Oil Seals (Sandwich Plate Gaskets)
#41
Posted 21 July 2015 - 03:52 PM
#42
Posted 21 July 2015 - 03:53 PM
These were supplied to GM by Lotus. My friend at lotus called the original manufacturer to see if they would make more but no joy unless we order stupendous amounts. I believe they are made from aluminium wire which is rolled to make it flat with the raised bit and then copper coated and teflon coated.
Can we not 'just' drill and tap the oil filter housing for the two connections that are in the sandwich plate?
#43
Posted 21 July 2015 - 04:56 PM
Edited by gertje, 21 July 2015 - 04:56 PM.
#44
Posted 21 July 2015 - 04:57 PM
I think they are made from copper, then aluminium plated and the PTFE coated, this is to ensure that there is no contact between the copper and the aluminium of the filter housing as this raises corrosion issues. Did I read somewhere that the Dutch VX chaps had done just what you suggest, drilled and tapped the filter housing?
#46
Posted 22 July 2015 - 08:55 AM
That sounds more like it.
Afew 100k were needed on an order.
Yes you did http://www.vx220.org...s/#entry1741496
Personally I think this is a more realistic, long term solution. It just needs a way of doing it in place without getting swarf in the engine. Might have to play a bit. If it's just 2 M12 tapped holes it shouldn't be too hard.
#47
Posted 22 July 2015 - 09:56 AM
#48
Posted 22 July 2015 - 10:12 AM
Or you can mod the Z22SE filter housing to retain the Z22SE oil cooler layout...
pics (Belgium Speedster guy) :
Edit; pics not allowed here, so check this => http://speedsterclub...cd63f&start=120
2 x M12 threads and done.
Anyone know what the thread size is?
#49
Posted 22 July 2015 - 10:13 AM
I'd guess M12 but things are never usually that simple. My thought was to strip out the filter, bung up the housing, make a drill jig to ensure you dont wobble!, drill, tap, hoover out the pot, refit, done.
#50
Posted 22 July 2015 - 10:54 AM
I know M12 but what pitch, 1, 1.25, 1.5?. As you say a rag down there with a vac running whilst drilling should be fine. I change the oil and filter after each half hour quali and 1 hr race so I cant be doing with trying to seal the sandwich plate everytime without new rings. I've got a shagged engine in the lock up so I'm going to have a practice on that.
#51
Posted 22 July 2015 - 11:30 AM
Ah yes, the thread might be in the epc.
#52
Posted 22 July 2015 - 12:05 PM
AFAIK original threads for the oil hose adapters on the Z22SE are coarse M12x1.75 which is a common 'bolt' thread but not very common for adapters/hoses.
Also after drilling and tapping these holes don't forget to install the spring-loaded oil diverter in the filter housing (also photos on the speedsterclub thread a little lower), otherwise the oil won't go through the cooler but uses the normal oil gallery inside the block.
#53
Posted 25 July 2015 - 06:44 AM
#54
Posted 27 July 2015 - 11:45 AM
Update on prototype gaskets as promised. Have received the first batch of prototypes comprising four different gaskets, two different thicknesses in graphite on a stainless mesh and two in different types and thicknesses in PTFE. This company felt, like all the others, that the original spec of gasket would be tricky to make and that there were other materials available that would be at least as good if not better hence the different materials. These will be going off to BoT for track testing later this week, more in due course.
#55
Posted 27 April 2017 - 05:18 PM
So
My car is leaking oil and Mat is out of stock
Any idea what has happened regarding the above before I start looking at alternates?
#56
Posted 28 April 2017 - 08:39 AM
I've got some of Mats here Jules if you want to use these and then replace when Mat has some in stock?
#57
Posted 28 April 2017 - 08:41 AM
We settled on the Graphite on Stainless mesh in the end as this gave the best 'feel' on the spanner although all the prototypes performed faultlessly under test. The first batch went into production last May and can be bought from Back on Track, Jon Seal, QMech and Phoenix Motorsport. Please PM me if you are having problems with this.
#58
Posted 28 April 2017 - 09:39 PM
Respect to Chris for the offer here...
There has been some dialogue in the background between me, Mitch (mike) and others regarding the gaskets
All good news though, this community is fcuking great
I would suggest, given the seeming outcome, that Madmitch starts a new thread to clear up where the gaskets are available from
Respect to Mat either way as well. I'm not 100% what was agreed with Mat/Mike but Mat (and Mike) deserve a massive applause and appreciation for sorting this out for us
Over to you guys then . From my meagre googling over the last few days this is the only vx/speedster thread of any help
/beer
#59
Posted 29 April 2017 - 08:33 AM
Thanks Jules, kind words and much appreciated.
Huge credit to Mat though, who has kept the entire VX community afloat when there was no other source of supply and who has very generously allowed me to step into his marketplace without any suggestion that it was his territory. Thank you Mat, much appreciated too.
I need to speak to my manufacturers on Monday as it is almost a year since the first production batch was made, to check that pricing and lead times have not changed since then. After that I will start a new thread on 'Car Parts For Sale'.
In the meantime, if you need sandwich plate gaskets they should be available from the four suppliers mentioned above or alternatively PM me direct, I have plenty here. Cost of gaskets from stock is £15 per pair plus £4 postage for up to four pairs, 5 pairs or more will be post free.
#60
Posted 01 May 2017 - 01:47 PM
