Painting / Powder Coating Hub Carriers
8 replies to this topic
#1 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 05 July 2015 - 07:06 PM
When having hub carriers painted / powder coated, what do people do with the internal bore where the hub sits?
If it is painted / powder coated it will make it a too tight fit for the hub, but leaving it bare will result in it rusting and then seizing the hub...
What have other people done?
#2 VX220BOB
VX220BOB
  • 625 posts
Posted 05 July 2015 - 07:14 PM
When I got mine shot blasted, then a small smudging of grease on the faces prior to painting, then when paint dry wiped of the painted grease then put a small smidge of clean grease on the faces again. Vaseline will do the same job.
#3 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 05 July 2015 - 07:25 PM
There is enough room with paint. The built up rust is what seizes the gap.
#4 TazN
TazN
  • 2,931 posts
Posted 06 July 2015 - 06:45 AM
If you are getting them powder coated they should block of anything that is needed, the guys I used had some kind of high temp metal tape. I think I only had to scrape out one set of holes they had over looked.
#5 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 06 July 2015 - 07:02 AM
My concern was more around if the bore wasnt painted, how have people protected it from not rusting - which will then cause the hub to seize in place...
#6 TazN
TazN
  • 2,931 posts
Posted 06 July 2015 - 07:10 AM
I forget exactly what I had done but I believe it was zinc coated, very thin layer that shouldn't be a problem for fitment.
#7 FLD
Posted 06 July 2015 - 07:19 AM
I had mine galvanised (triple plate) and then passivated to prevent the zinc from being erroded.
#8 Arno
Arno
  • 1,238 posts
Posted 06 July 2015 - 07:32 AM
Galvanisation should not cause problems as the buildup is quite limited and the material is relatively hard.
Paint/powdercoat can be an issue in the bore with the reduction in diameter and also on the mating surface between the upright and the hub pack.
It usually gets too thick and forms a soft(er)/compressible layer which is not good for a solid connection like you want between the hub and upright.
If uprights are painted/powdercoated I'd recommend removing the paint from the bore and the mating surface where the hub unit sits. Spray some corrosion inhibiter on the metal when fitting and it should be fine. Washout will be minimal/nonexistent and it should keep moisture out and stop most corrosion.
#9 oblomov
oblomov
    oblomov
  • 3,878 posts
  • Interests:Mumblers
Posted 06 July 2015 - 11:14 AM
I keep the mating surfaces clean, then apply waterproof grease and wipe off.  On the inner bore I keep clean and coat with Dinitrol 3654 but you could use either on both surfaces, or any other corrosion inhibitor so as Arno says "Spray some corrosion inhibiter on the metal when fitting and it should be fine. Washout will be minimal/nonexistent and it should keep moisture out and stop most corrosion." thumbsup
