This post keeps cropping up in forum searches:
Spitfire Engineering, on 12 Apr 2013 - 12:22 AM, said:
Regarding your setup, is the installation noisy? If so it allows a possibility which may help and save you a lot of money. Basically the unit has an eductor which is tuned to the output (well more accurately the return) pressure. If you just fit the Walbro without adjusting this it usually results in high pressure return fuel hitting the lid of the pump unit and flying out sideways, outside of the pump canister, this fuel normally gently flows over the top of the standpipe and into the can. What this means in reality is the return fuel which should not only be returned to the canister but also suck in fresh tank fuel via the eductor principle as well, is mostly sprayed back into the tank reducing the fuel in the canister for the next corner. We have sold loads of S2/VX units to Bernard for the Audi Elise conversions all without issue and they make similar outputs. If you are going to hard track the car at tracks with long left handers then a swirlpot or trapped tank is needed, the advantage of a trapped tank is that it keeps a single in tank pump, personally I am not a fan of several feet of HP fuel hose and several components in the engine bay.
How would I go about modifying the unit to prevent this?
Message sent
