Stage 4 Owners - Eds Uprated Manifold
20 replies to this topic
#1 denno
denno
  • 1,528 posts
Posted 17 July 2015 - 10:27 AM
Stumbled across a thread recently about the eds manifold and its benefits for higher power cars. Doesn't seem much info on here when searching but one one particular owner seemed to really rate the upgrade. As we all know turbo stage 4's delivery is on the savage side but this manifold is supposed to help with a smoother power delivery, a wider power band and extra power higher end. Do many stage 4 owners have this manifold and agree with the benefits it gives that I have mentioned?
#2 siztenboots
Posted 17 July 2015 - 10:30 AM
yes
#3 T VXT
T VXT
  • 433 posts
Posted 17 July 2015 - 10:36 AM
I fitted one recently, I like it!   Here's a link, my comments on the manifold are about half way down this post http://www.vx220.org...eavy/?p=1791466
#4 denno
denno
  • 1,528 posts
Posted 17 July 2015 - 10:38 AM
yes
Makes me wonder why all stage 4+ cars don't upgrade to this then, unless a smoother delivery is a bad thing 😄
#5 denno
denno
  • 1,528 posts
Posted 17 July 2015 - 10:40 AM
You're the owner I was referring to 😊 Great rebuild thread by the way, seriously fair play and well done to you.
#6 siztenboots
Posted 17 July 2015 - 10:41 AM
the issue is that the clearance to the boot lid is close
#7 T VXT
T VXT
  • 433 posts
Posted 17 July 2015 - 10:43 AM
Cheers thumbsup It's quite a bit lighter too, 2kg+ http://www.vx220.org...eavy/?p=1782232
#8 Bumblebee
Bumblebee
  • 7,592 posts
Posted 17 July 2015 - 10:48 AM
I noticed a big difference when I upgraded to a Klassen manifold but I also fitted a 3" exhaust at the same time. A lot smoother now :)
Edited by Bumblebee, 17 July 2015 - 10:51 AM.
#9 denno
denno
  • 1,528 posts
Posted 17 July 2015 - 10:51 AM
What's the solution?
#10 T VXT
T VXT
  • 433 posts
Posted 17 July 2015 - 10:52 AM
I have the real eds (not the ebay one) and fits perfectly with my MMG big tophat, no issues with clearance. Sorry for all the links - here's a pic of the top hat, it might be a bit lower than the Courtney tophat http://www.vx220.org...eavy/?p=1789627
Edited by T VXT, 17 July 2015 - 10:53 AM.
#11 denno
denno
  • 1,528 posts
How much was that manifold and any issues with the boot clearance? Eds manifold is just over 400 quid from Regal I think.
#12 denno
denno
  • 1,528 posts
Posted 17 July 2015 - 10:55 AM
I have the Mmg top hat, where did you order the manifold from?
#13 Bumblebee
Bumblebee
  • 7,592 posts
Posted 17 July 2015 - 11:01 AM
It was a long time ago now when I bought it and had it fitted by MMG,think it was a year ago and I paid £500 from Courtney's? No problems with boot clearance and it fitted fine
Edited by Bumblebee, 17 July 2015 - 11:03 AM.
#14 T VXT
T VXT
  • 433 posts
Posted 17 July 2015 - 11:03 AM
My was new, but from a member on here who never got round to fitting it, so saved some pennys. You can get a thicker thermal inlet gasket too, most come with longer studs to accommodate the wider gasket
Edited by T VXT, 17 July 2015 - 11:03 AM.
#15 slindborg
Posted 17 July 2015 - 12:48 PM
the less  money you can give to lageR the better, otherwise you are simply encouraging them and that's just wrong!
#16 denno
denno
  • 1,528 posts
Posted 17 July 2015 - 01:22 PM
;) if there is another source for similar price I agree. Would there be any benefit of doing this though with only a 2.5" system and 100 cell cat? In the old days on here it seemed the 2.5" systems would suffice for a 300 bhp stage 4 vxt, nowadays talk seems to suggest a 3" system is required!
#17 Nev
Posted 17 July 2015 - 01:43 PM
What power is yours making at the moment? This manifold "makes" more power by shortening the length of the runners and making them a bit tapered. This is at the "expense" of losing some low end torque. So you will only really see any benefit from about 5000 RPM onwards if you turbo/map can still puff air into the engine at that RPM. FYI, the EDS manifold is a direct copy from a previous incarnation of a manifold for a different Vauxhall engine. I don't think a great deal of science/experimentation went into it's design personally. The Klassen manifold had some flow analysis done on it and went through several prototypes with a spec of being used on 300 to 500 BHP engines.
Edited by Nev, 17 July 2015 - 01:46 PM.
#18 T VXT
T VXT
  • 433 posts
Posted 17 July 2015 - 04:25 PM
The only torque I lost was the torque spike when the turbo spools up. Which is "bad" torque....
Instead I have a smoother torque curve peaking at ~335ft/lb
#19 denno
denno
  • 1,528 posts
Posted 17 July 2015 - 08:11 PM
Nev, have sent you pm. And T VXT, that's what makes this mod appealing if it smooths out the delivery, few extra horses would be an added bonus :)
#20 kipper
kipper
  • 2,364 posts
    Smoking various types
    of fish.
Posted 22 July 2015 - 05:20 PM
When I fitted the Klassen manifod to my +2 stage, you certainly could see the short coming and advantages of this manifold. Low down torque certainly dropped off ( I would say anything up to 4000 RPM, because of the short runners), while upper end breathing was certainly inproved. Now that the map has gone in to compliment the new turbo and 3" exhaust I will have to await my conclusions, until I find out the problem with the main ECU or wiring.
