Oil Overfill - Peugeot 107
5 replies to this topic
#1 mark_vx
mark_vx
  • 667 posts
  • Interests:Wife and kids, VXs, space, toast - in that order!
Posted 19 July 2015 - 08:17 PM
I have just checked my Peugeot 107 oil and it appeared slightly low so I topped it up. When I checked it again I am not sure whether O have overfilled it. If I put the dipstick in for about 5 seconds and pull it out the level looks about half way between max and min. If I put the dipstick in for about 30 seconds it looks as if I have massively overfilled it.
Anyone else had this experience.
Should I be worried?
#2 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 20 July 2015 - 07:33 AM
How much did you put in?
#3 fezzasus
Posted 20 July 2015 - 07:58 AM
Generally, you shouldn't need to top up oil between oil changes in a modern engine. By all means check, but check a few times with the engine hot or cold.
#4 Tibbles Stryker
Tibbles Stryker
  • 1,941 posts
Posted 20 July 2015 - 11:51 AM
I used to put about half a litre in the aygo between services, as above it hardly used any oil and probably wouldn't of hurt if I'd left it.
#5 mark_vx
mark_vx
  • 667 posts
Posted 20 July 2015 - 12:15 PM
Didn't measure it but I would say between a 1/2 litre and a litre.
I checked it again this morning and I think I am OK, it's just there is a line of oil above what looks like the level on the dipstick.
I am at work now si I have travelled around 30 miles in it, nothing drastic has happened.
#6 slindborg
Posted 20 July 2015 - 12:38 PM
"usually" (depending on sump capacity) the min-max is 1Litre... if it was only "a little low" then a litre is overfill time.
oil vaccummmmm and suck out the excess
