Posted 25 July 2015 - 10:33 AM
I've stripped the car and all parts now have prices, I've sold a few things already but if anything is not listed below please ask.
Everything is off the chassis so can be shipped whenever, feel free to make an offer for multiple parts or if you want pics of anything. Delivery will need to be added to all prices, I' d obviously prefer collection if possible. Car was Europa blue NA '03 plate.
62k mile 2.2 engine with all st.2 sc and associated parts, charge cooler tank and pump, billet flywheel, ecu, wiring, uprated clutch, dyno print outs, stacks of history and paperwork etc. Note rad is bent slightly and fans have some damage to plastic covers but spin freely and the charge cooler has a very slight kink to it. These can be pressure tested or thrown away if not wanted, but will include these. The conversion was done by Courtney and all new parts were used, its had a new gm timing chain fitted a few years ago and has been well looked after with regular oil changes etc. If the vibratecnics side mounts aren't sold I'll include these. £2k.
Three black ATS DTC rims with very good re050 tyres, NSF wheel and tyre will need to be replaced, got a price of 278 euros delivered for replacement, the wheels are matt black which they don't do as standard so will need to powder coat, could be a good chance to get a custom colour, there's a few light scuffs on the wheels which doesn't show unless looking for them - £450
Front calipers - £150 pair
Ns rear light good condition but two mounts have broken - £175
Os rear light good condition £225
Os front light small chip in top corner and the units inside are loose so mounts are broken - £100
I'm getting the ns front intrax 1k2 damper repaired so will sell as a kit soon hopefully
Spitfire toe link and brace bar kit which clears the miltek system - £200
Carbon fibre door and handle inserts (matt) - £120
Centre pod with sc boost gauge and clock with wiring and hoses - £90
Will covers, both in good condition - £50 each
Rear turbo spats \ mudguards - £50
Front turbo splitters bit tatty but will look OK fitted - £30
Soft top in good condition and watertight, although 2cm of loose stitching near corner - £250
Rear clam has small chips where passenger door pressed into it but easy filler repair, other than that in good condition - £350
Powder coated wishbones (all except NSF available) which had new bushes and ball joints fitted 2010 an has covered around 20k miles since - £50 each.
Engine under tray, missing one vent, good condition - £80
Manifold heat shield good condition £20
Driveshaft heat shields GC -£20
Arch liners (except NSF) a few rub holes £35 each
Storage pockets by doors - £15 pair
Steering wheel with no airbag - £20
Boot carpet - £15
Na vents - £10
Ns inner door panel, slight damage - £20
Os inner door panel GC -£40
Ns wing mirror with base, few scuffs - £15
Boot lid GC - £50
Bonnet crack in corner -£10
Roll panel with aerial and brake light - £50
Drivers door with mechanisms and mirror, few stone chips when looking for them - £50
Rear subframe -£150
Rear engine mount with poly insert -£20
Very nice black leather seats with slight wear and good runners -£400
Roll bar -£50
Rear screen -£50
Silver plastic centre tunnel pieces few scratches and marks -£20
Stack dash with approx 51k miles on - £75
Brake servo and master cylinder - £30
Pedal box assembly -£40
Speaker panel -£30
Any other bits wanted, just ask via pm but I have sold a few parts already.
