Hi
I have stage 2 SC on CS map. The engine has always ran badly if driven straight away from stone cold. It won't rev above 2-2.5k and misfires and splutters. It only lasts for maybe half a mile at most then clears, although there is always a slight flat spot at part throttle at 2.5k even when warm.
I always thought this was just a 'feature' of the CS map so never really worried about it. Work around (if I can be arsed) is to let the car idle for a few minutes from stone cold before driving.
Lately though, when this misfire happens the rad fans sometimes come on permanently. I have to stop once the car's warmed up a bit, turn the engine off and on again to clear the fans. There is no EML light. I read the ECU codes and it had 1 fault recorded but the code reader reported N/A for the code.
I just wondered if anything can be done, or anything to try. (I know, get the Dutch software..)
Is this just CS map normality and live with it, or a sign of something else wrong?
cheers
