Light Weight Battery
Posted 17 August 2015 - 04:24 PM
Posted 17 August 2015 - 04:35 PM
Posted 17 August 2015 - 04:40 PM
Posted 17 August 2015 - 04:48 PM
Mine also goes on trickle charge. Can the trickle charger be on while the battery is plugged into the car or do you have to disconnect the battery? Il be running a good sounds systems, digital dash with plugs in, gauges, tablet for the software, sat nabs,Iphone chargers, road camera that keeps recording even when the car is switched off but has a cut off point once the battery reaches a certain drain so was making sure it can cope with all this.There is ni problem with the gauges because I also have some,(don't forget my project that I run ), The only thing is that I have a battery charger after every ride I put it on the socket
That does sound light but how much is it and what's the amp power? 😀I put a shorai lithium one in my Elise 1.3kg!!! 10kg saving and About 1/3 size. Part no LFX21A6-BS12
Posted 17 August 2015 - 04:50 PM
Posted 17 August 2015 - 04:53 PM
How was it for running the car with lots of gadgets and did you ever find out how long it last before it went dead? Any pictures of how you fitted it and making the terminals work?I got mine off eBay £150 delivered. 330cca.
Posted 17 August 2015 - 05:08 PM
Posted 17 August 2015 - 05:15 PM
Posted 17 August 2015 - 05:21 PM
Posted 17 August 2015 - 05:46 PM
But, does it make any discernible difference, I mean....I'm usually the most geeky weight weenie but I'm struggling to think a few kilos on the front(lightest end) is going to improve things. I'd rather save weight over the rear to help weight distribution. Saving weight on the front will worsen weight distribution, so unless it leads to better acceleration, which I can't see, then surely its just an exercise in spending money and adding faff.
Posted 17 August 2015 - 05:52 PM
Posted 17 August 2015 - 05:59 PM
Posted 17 August 2015 - 07:45 PM
I don't have any stereo or anything it's a track car. I thought the alternator powers everything when engine on?
This. Unless you are watching movies in a car park the alternator is in charge of the power. Small battery wlll need to be kept trickle charged to ensure enough cranking power.
Posted 17 August 2015 - 08:01 PM
If there is nothing draining it like alarm they reckon these lithium batteries will still crank after 12 months.
Posted 17 August 2015 - 08:47 PM
When I got my NA it had a smaller lightweight battery in! It drained on my first winter,after reading many horror stories about getting the battery out, I set to work, reached in and pulled it out, piece of p*ss Wondered what the fuss was about until I got the new one and thought HOW F*UCK DOES THAT GO IN THERE!!!
Oh and mine was held in with Polystyrene! (i assume to keep down on weight!)
Edited by GiGo, 17 August 2015 - 08:49 PM.
Posted 17 August 2015 - 11:11 PM
It will only be going for good blast out so that should be fine and the rest of the time will be on trickle charge.Once your running the altornator should do most of the work. Where it won't work is short journeys with repeated starting and being left for weeks without disconnecting it. So depends how your going to use the car, if you're going to use a charger and/or isolating it.
Posted 17 August 2015 - 11:16 PM
The lotus s2 range from standard run there battery's in the rear with no problems so I think are cars should be fine. It's more about the size of the battery for me as its a pain in the back side the big 063 battery to get in and out.But, does it make any discernible difference, I mean....I'm usually the most geeky weight weenie but I'm struggling to think a few kilos on the front(lightest end) is going to improve things. I'd rather save weight over the rear to help weight distribution. Saving weight on the front will worsen weight distribution, so unless it leads to better acceleration, which I can't see, then surely its just an exercise in spending money and adding faff.
Posted 18 August 2015 - 06:39 AM
Edited by Nev, 18 August 2015 - 06:40 AM.
