Hello
I have a problem with my vx220 turbo. I will try to make a long story short.
It started with a strange value on my wide band lambda, it was too rich.
I changed the lambda sonds but it was no different. So i think that it maby was a leak in the turbo pressure system.
So i make a pressure test. I locked the hose after the air meter and made a small hole in the locking. Took the compressor and
pressed a couple of bar (3-4bar) into the system. The charge cooler have a leak. So i fixed the charge cooler and mounted together the car. When i test drive the car the AFR was ok but i only have 1 bar in turbo pressure, before i have 1,4 bar.
I think i have broken something in the system when i put on the pressure from the compressor.
Do you have any idea of where to start troubleshooting.
best regards Fredrik
