Shot Blasting/ Sand Blasting Remove Zinc Plating?
Posted 08 September 2015 - 01:59 PM
Posted 08 September 2015 - 02:34 PM
you'll remove the zinc plating. I would also be reluctant to paint over loose powdercoating because the powdercoating could still flake off, removing the paint with it.
Edited by fezzasus, 08 September 2015 - 02:35 PM.
Posted 08 September 2015 - 03:05 PM
Posted 08 September 2015 - 03:14 PM
Why not chemically strip the powdercoat? 1:1 DCM / MeOH should do it and shouldn't affect the zinc plating.
Posted 08 September 2015 - 04:27 PM
I was going to remove as much as I could as it's just flaking off and hopefully build it back up with the por paint.you'll remove the zinc plating. I would also be reluctant to paint over loose powdercoating because the powdercoating could still flake off, removing the paint with it.
Posted 08 September 2015 - 04:28 PM
Il have a look into the 2k paint. Is it better then the por 15 paint?sand blast the lot off and get painted 2k instead mine still Look like new and for what zink coating there is left after blasting Wouldnt make much difference unless you get then re dipped Then paint.
Posted 08 September 2015 - 04:29 PM
I take it that's something I could do myself at home or is it a professional job?Why not chemically strip the powdercoat? 1:1 DCM / MeOH should do it and shouldn't affect the zinc plating.
Posted 08 September 2015 - 05:04 PM
Posted 08 September 2015 - 06:16 PM
We never used powder coating because it can hide corrosion of the metal component underneath. Eventually the powder coating will crack and split off but by then the damage is done and the object you were trying to protect is beyond recovery. Hot zinc dip provides both a chemical and physical barrier and takes a lot of beating.
Posted 18 September 2015 - 09:22 AM
