So I followed the guide and changed the central locking backup battery in the boot of my vxt and had to sort out the 'secret button' too as it was stuck in one position.
Now am happy the battery is connected and the switch is working when pressed but I am not hearing any kind of click (which from what I have read I should hear) when I press the button even in my garage with the door closed.... I am assuming that the button activates a relay, and that could be the problem, could anybody point me in the direction of the correct relay or offer any other advice on checking if it is working?
Thanks
Backup Boot Battery - No Clicking
Started by
vx220bass
, Sep 11 2015 07:40 PM
6 replies to this topic
Posted 11 September 2015 - 07:40 PM
Posted 11 September 2015 - 08:25 PM
Are you pushing the fob at the same time? fairly sure you need to do both.
Posted 11 September 2015 - 08:48 PM
The button should activate a relay under the dash. There are windscreen wiper,, flasher and backup batterie under there.
Posted 11 September 2015 - 08:50 PM
Relays
http://www.speedster...ument panel.pdf
Relay K104 here
http://www.speedster...oor locking.pdf
Posted 12 September 2015 - 06:51 AM
Thank you, that looks like the next logical thing to check.
Just to double check before I take the faceplates and dashboard off we are talking about it being located underneath the dash itself?
Posted 12 September 2015 - 07:38 AM
No in the passenger footwear. Contortion time to see them
Posted 12 September 2015 - 07:59 AM
Great, would say that makes it a bit easier to access but then it involves getting in the footwell of a VX....
Thanks again
