This 'heel Toe' Malarkey
Posted 24 September 2015 - 12:39 PM
Posted 24 September 2015 - 12:45 PM
Posted 24 September 2015 - 12:49 PM
Most critical function is to avoid locking the rears on downshifts (avoids placing the load of raising engine revs to match transmission speed on the rears). Not so critical in MRE cars (I can't do it in the VX), very critical in front engined vehicles.
Posted 24 September 2015 - 01:11 PM
Posted 24 September 2015 - 01:15 PM
less wear on the clutch?
Posted 24 September 2015 - 01:16 PM
All cars can benefit though regardless of layout as generally not h&t ing will over brake the car and will slow you down over a lap. You can get away without doing it in the dry in my car but in the wet it is almost essential. It's dead easy to do in a 7 though as the pedals are so close together.
Posted 24 September 2015 - 01:18 PM
I cant rotate my leg in the VX (and being a sh*t driver) so I just use the side of my foot
Posted 24 September 2015 - 01:36 PM
It allows you to brake later without unstabilizing the car. If you are braking at 100% on the rear wheels, if you change down without matching the revs it slows the wheels down past the limit of friction (as the brakes are holding them at 100% best case). This means you lock up the back wheels.
Plus a rev matched gearchange is faster so you have more time with 2 hands on wheel when braking. Plus it sounds cool
Posted 24 September 2015 - 02:03 PM
I doubt many people actually use their heel and toe, you'd need a floor mounted pedal or an extended pedal. I use something more along the lines of "three toe, two toe and some of the foot". Its not as snappy sounding though.
Edited by Mattyboi, 24 September 2015 - 02:03 PM.
Posted 24 September 2015 - 02:47 PM
Posted 24 September 2015 - 02:49 PM
From the master himself: -
Posted 24 September 2015 - 02:57 PM
Ah! Makes perfect sense. I did find I was quite jerky on down shift at Anglesey many moons ago. Not sure I'll be doing it though as I've much more to learn about like braking etc. Thanks for the great explanation though. If anyone fancies giving me some pointers on Saturday I'd really appreciate it!
I'm good at it and the effect is more noticable in my car, just come and find me.
Posted 24 September 2015 - 03:04 PM
Posted 24 September 2015 - 03:46 PM
Posted 24 September 2015 - 04:16 PM
Heel and toe is tricky to get right because you can either: brake too hard when trying to press the gas or give too many revs which will jolt the engine. Get it right and you can literally drop the clutch after a downshift which allows you to get on the power again earlier.
Pointers:
I learnt it by doing it at low speeds on the public road when no one is following me just to get a comfortable foot position, depending on the pedal layout it can either be my heel or side of my foot I use for the gas. Although at low speeds it's very hard to get the correct amount of gas and easy to over rev so still bring clutch up carefully. When I was more comfortable with foot position and wasn't stamping on the brake when trying to press the gas I did it at higher speeds, easier to get revs right and then at max speed on the track, easier still to get revs correct as it's hard to over rev when you are near max revs
I find left foot braking is also very helpful when a corner doesn't require a downshift as you can get on the brakes later which actually makes a surprising difference. Also gentle left foot braking is good for instant speed corrections mid corner, my left foot is always hovering over the brake pedal on long sweeping bends when at the limit of traction. Be warned though, most people stamp on the brakes the first time they try with their left foot as they're used to pressing the clutch with this foot, start gradually with no one behind and build yourself up.
I've been using heel and toe for around 10 years now and left foot braking for the last year and they're pretty automatic now, heel and toe is one of the best bits about a manual and one of the reasons I am sticking to manuals at the moment even though the dual clutch systems are so good. They're just not as fun in my opinion.
Edited by gaffer1986, 24 September 2015 - 04:17 PM.
Posted 24 September 2015 - 04:26 PM
Another pointer, I find it far better when I blip the throttle before selecting the lower gear instead after selecting it. The gears just seem to go in easier when the revs are match to wheels.
Posted 24 September 2015 - 04:39 PM
Posted 24 September 2015 - 04:57 PM
I've been gradually practicing it over time. I find it far easier in the VX to cover both pedals with my wide (fat) foot and blip the throttle by tilting my foot over.
As said its at least a bit of fun and quite satisfying when done well
Posted 24 September 2015 - 09:46 PM
Posted 25 September 2015 - 07:41 AM
I've got quite narrow feet, so I put the ball of my foot on the brake, then twist and jab the throttle with the side/heel. I can only do it when braking hard as the VX brakes are overservoed, so it's much easier on track.
