Harness Bar
Posted 07 May 2003 - 09:28 PM
Posted 07 May 2003 - 09:39 PM
Posted 07 May 2003 - 11:34 PM
Posted 08 May 2003 - 07:48 AM
its indeed too high...I will keep the bar about 2-3 inches lower, with appropriately sized mounts. those will provide the (solid) support for height, while resting against the rear of the rollbar will offer plenty support against forward tensing strength.The upper belt mount is a bit high for a harness but would be interested to see how you get on.
bear in mind that I am keeping all the rear plastic lining off the car, so I have no problem with trimming away parts....that will necessarily happen if you decide to keep it on.....
exige has a bare shell as well, w/out plastic insulation.....
I tried to position a 40 mm diameter, but it looked and felt too big....
powder coating is an option for sure, but even the satin finish is quite good as it is...
Edited by Ricky2772, 08 May 2003 - 07:54 AM.
Posted 08 May 2003 - 08:00 AM
Posted 08 May 2003 - 02:24 PM
Posted 08 May 2003 - 04:24 PM
some "L" shaped mounts soldered to the bar and screwed to the belt point.Ricky
How do you propose to connect the mounts to the roll bar? Welding?
I too am thinking about replacing the plastic thing at the back. I may even carpet a bit of it but not go above the shelf thing...
it is surely easy to place some nice, light carpeting instead of that black plastic.
dunno how to deal with the speakers though. binned long ago for me...
Posted 08 May 2003 - 04:26 PM
straps should travel parallel or a bit from below up, from bar to shoulders.How would you propose to lowering the bar from the height of the belt mounts? How high should it be above shoulder? Is there a distance between shoulder belts on bar?
width is parallel or a bit tapered to your shoulder width.
Posted 09 May 2003 - 08:09 AM
Posted 09 May 2003 - 04:19 PM
Posted 09 May 2003 - 07:25 PM
Thanks GM!Elise has additional bushes on the rollover bar to allow a harness bar to be fitted and we don't
