- Fronts are 7 ½Jx17 with 205/45/17 tyres
- Rears are 8Jx18 with 225/40/18 tyres
Wheel Offset Help
Posted 08 October 2015 - 11:28 AM
Posted 08 October 2015 - 11:49 AM
Posted 08 October 2015 - 12:00 PM
Standard wheels offset:
Front E26
Rear E36
Therefore you will need a 9mm spacer for both the the front and rear to match the OEM offset and keep the scrub radius the same and bump steer to minimum. The spigot on the standard hub is around 15mm so you will still have some spigot left to mount the wheel for ease of installation. Don't worry that you have less spigot because the spigot does not help hold the wheel on, the wheel is kept in place front the friction between the face of the brake disc and wheel. The bolts don't receive lateral force.
Of course this is assuming your current offset is E35 front and E45 rear.
Edited by gaffer1986, 08 October 2015 - 12:03 PM.
Posted 08 October 2015 - 12:04 PM
By the way, how are you finding the big front wheels? I found bigger front wheels gave me less steering feel and more tram lining.
Posted 08 October 2015 - 12:06 PM
He doesn't drive it for sportiness or handlingBy the way, how are you finding the big front wheels? I found bigger front wheels gave me less steering feel and more tram lining.
Posted 08 October 2015 - 12:14 PM
If you saw the LEDs, Neons, AirHorns, Spoiler... you'd know this
Harsh but ... fair!
I literally only drove it around the block before putting my OEM's back on.
I am going to be doing about 450 motorway miles a week this winter so thought something wider would be more sturdy.
Once I have new tyres I'll let you know how it goes.
Posted 08 October 2015 - 12:18 PM
This is what is stamped inside the wheels - is it worth double checking by measuring it (I've seen a few guides on how to)?
Posted 08 October 2015 - 12:31 PM
If the rears are 225/40/18 then they are the same width as standard rears (225/45/17). Also @ 205, the fronts are the same size as those that run "rear wheels" on the front and then use 205/45/17 tyres iirc.I am going to be doing about 450 motorway miles a week this winter so thought something wider would be more sturdy.
Posted 08 October 2015 - 12:32 PM
Posted 08 October 2015 - 12:33 PM
Cool, will be interesting to hear about it.Harsh but ... fair! I literally only drove it around the block before putting my OEM's back on. I am going to be doing about 450 motorway miles a week this winter so thought something wider would be more sturdy. Once I have new tyres I'll let you know how it goes.
Posted 08 October 2015 - 12:34 PM
Posted 08 October 2015 - 07:41 PM
Posted 08 October 2015 - 09:05 PM
Posted 08 October 2015 - 09:31 PM
Posted 09 October 2015 - 07:57 PM
Posted 09 October 2015 - 09:00 PM
Posted 10 October 2015 - 07:46 AM
Posted 10 October 2015 - 10:09 AM
205 is much better than 2015. It rub less thann 2015.
Posted 10 October 2015 - 10:42 AM
Front 7.5j so 190mm Back 8j so 203mmHow wide are the wheels? This will dictate how to get back to the right position
Posted 11 October 2015 - 01:25 PM
