Sc Work On My Car?
Posted 09 October 2015 - 09:38 PM
Posted 09 October 2015 - 09:51 PM
Thank fcuk there's another NE mug with a little plastic shitbox. a was beginning to think it was only me and redvts.
Posted 09 October 2015 - 09:52 PM
Posted 09 October 2015 - 10:04 PM
Posted 09 October 2015 - 10:17 PM
2k hesitation seems strange. faulty lambda maybe? italian tune needed?
Posted 09 October 2015 - 10:39 PM
Posted 10 October 2015 - 07:15 AM
if you can post a picture of the engine bay (especially the wiring loom and ecu) it might help in your search, because different people modify them in different ways
Posted 10 October 2015 - 07:22 AM
The 2k rpm flat spot might be the courtenay map - mine has always done it.
Posted 10 October 2015 - 07:35 AM
Posted 10 October 2015 - 07:57 AM
Am working on mine in South Shields today if you wanna pop over
Posted 10 October 2015 - 08:24 AM
2k flat spot is common on courtney map. Mine has it.
Your power is safe on standard engine. Dont go messing with anything
Posted 10 October 2015 - 08:57 AM
Posted 10 October 2015 - 09:00 AM
Posted 10 October 2015 - 11:04 AM
Posted 10 October 2015 - 12:31 PM
Instead of changing your engine, invest in the OBD tuner software. That will make the pick-up at low revs completely different with possible some extra power up top.
Posted 10 October 2015 - 12:40 PM
With some ignition tweaks2k flat spot is common on courtney map. Mine has it. Your power is safe on standard engine. Dont go messing with anything
Posted 10 October 2015 - 12:50 PM
Spot on, if you don't mind me asking what injectors and cams are in it? I don't know a great deal about these sc conversions? Baz.That's my old car and I did the conversion apart from the loom which was done by Vocky.
Posted 10 October 2015 - 07:33 PM
I believe it was on standard cams and z20let injectors when he did the conversion.
Posted 10 October 2015 - 07:49 PM
The injectors were z20let as Vocky has suggested but not standard cams - the car had an AMD stage 3 tune early on in its life, which included a lightend flywheel, ported head, cams, 200 cell cat(?), ITG carbon enclosed filter and miltek exhaust. When I sold it it had every receipt which list what the cams were(piper?).
I don't recall any flat spot when i had it.
I don't think I would go mad and change anything on that engine without doing the pistons and rods.
Posted 10 October 2015 - 07:55 PM
The injectors were z20let as Vocky has suggested but not standard cams - the car had an AMD stage 3 tune early on in its life, which included a lightend flywheel, ported head, cams, 200 cell cat(?), ITG carbon enclosed filter and miltek exhaust. When I sold it it had every receipt which list what the cams were(piper?). I don't recall any flat spot when i had it. I don't think I would go mad and change anything on that engine without doing the pistons and rods. Oh I won't be doing any more tweaks to the engine,it has a lot of power! More than happy with that,its just want to keep it reliable, Thanks for getting back to me on what's been done on it!
