Obd-Tuners Queries
18 replies to this topic
#1 Rosssco
Rosssco
  • 4,185 posts
Posted 18 October 2015 - 05:34 PM
So I've some issues with connection.
I keep getting a software not compatible issue, even though I have downloaded the latest version from the website.
It comes up as connected on the little indicator on the bottom right hand side when the program is open, but there is obviously no data displayed on the main screen (not sure if there's supposed to be..).
I've also been getting a misfire under load at about 3-4k rpm at about 50% throttle, and as of yesterday a consistant misfire at idle, and obviously its difficult to diagnose without access to the software.
Does the engine have to be running to access the ECU, or just at the ignition on position?
Thanks
#2 Bargi
Bargi
  • 4,483 posts
Posted 18 October 2015 - 07:01 PM
Check you've put the correct license key in. A wrong out no key will still connect but not do anything else
#3 CHILL Gone DUTCH
Posted 18 October 2015 - 08:42 PM
As bargi said go to the general tab and check the license key and press the test button When you press the test button the software creates a read only file which saves the key and baud rates
#4 CHILL Gone DUTCH
Posted 18 October 2015 - 08:43 PM
From experience it can be a issue the first time you use a laptop tablet but once it's working it's fine
#5 Rosssco
Rosssco
  • 4,185 posts
Posted 18 October 2015 - 08:44 PM
CHeers.
Yes I've tried the test button, and it passes the test..
#6 CHILL Gone DUTCH
Just full ignition required Good practice to hit test button before use
#7 Rosssco
Rosssco
  • 4,185 posts
Its a not ancient netbook, so should be ok..
#8 CHILL Gone DUTCH
Posted 18 October 2015 - 08:45 PM
Have you used it before ??
#9 CHILL Gone DUTCH
Posted 18 October 2015 - 08:49 PM
There is a section in instructions about setting within laptop To match the settings Also check All the wires are still attached on the car side of the obd port As if one ( white ) comes out lose it can pass the test but not send data
#10 Rosssco
Rosssco
  • 4,185 posts
Posted 18 October 2015 - 08:58 PM
No never used it before.
Cheers, I'll have a check. Did read the installation guide too..
#11 CHILL Gone DUTCH
Posted 18 October 2015 - 09:03 PM
Might sound daft but try a different port
#12 CHILL Gone DUTCH
Posted 19 October 2015 - 10:37 AM
Did you get it working
#13 Rosssco
Rosssco
  • 4,185 posts
Posted 19 October 2015 - 10:48 AM
Not had a chance Chris, and probably won't till the weekend...
#14 Rosssco
Rosssco
  • 4,185 posts
Posted 20 October 2015 - 04:17 PM
I'm in.
It was the licience key as noted about - I typed it in a few times, but then ended up accessing my email and copy / pasting it in, which worked - I think its space sensitive...
Just need to check my misfire.. I was thinking of installing a set of Z20LET Injectors now that I can change the settings - anyone know if this will have a detrimental effect given I'm on the base map? Obviously I'm not going to calibrate the thing with these (too small) but as an initial check it would be good..
#15 CHILL Gone DUTCH
Posted 20 October 2015 - 04:36 PM
Might be a good idea to put it straight in to learn mode If you plan on doing any type of reving driving But don't go mad As I assume you have a BIG spec as your using 630cc
#16 two4oneuk
two4oneuk
  • 731 posts
  • Interests:Cars
Posted 20 October 2015 - 05:49 PM
I've got a set zlet injectors in the garage. Not been used for a few years. Done less than 30k miles
#17 Rosssco
Rosssco
  • 4,185 posts
Posted 20 October 2015 - 06:18 PM
Yeah Peter suggested to do a log of it running and send it on.
Nothing particularly big - aiming for just under ~300bhp, but will see what I get.
#18 Rosssco
Rosssco
  • 4,185 posts
Posted 20 October 2015 - 06:21 PM
Cheers Martin. I've got a set of those which I've just stuck in, but I'm getting the same mis-fire issue, so feck knows what the issue is.. Hopefully some analysis of logs will indicate what it is..
#19 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 20 October 2015 - 08:51 PM
Your misfire, I'm still trying to pin point my issue.. see thread.. . http://www.vx220.org...o/?fromsearch=1 Maybe same symptoms
