So who's got the quickest/easiest/best technique and tools for drilling out the precat in an NA downpipe?
Posted 23 October 2015 - 12:57 PM
Posted 23 October 2015 - 12:59 PM
Posted 23 October 2015 - 01:23 PM
I used to stick them in a band saw and cut them across the middle. The cat lifts out and you weld it back together.
It's a lot faster than trying to drill it out
Posted 23 October 2015 - 01:30 PM
Posted 23 October 2015 - 02:19 PM
I've done it previously, just wondered whether there was a better/quicker/easier method
Posted 23 October 2015 - 02:39 PM
I used snipe nose pliers. Jam them into the substrate, twist and pull. Easier than drilling IMO.
Posted 23 October 2015 - 03:06 PM
Ask Furtive, and don't do what he did
Posted 23 October 2015 - 03:42 PM
Cool, cool and cool during drilling! Just a spray flask with water will save your drills and speed up the process. (You can be lucky that the whole thing comes loose; screw a big threaded screw-bolt in the material and pull/lever everything out with that.)
Posted 23 October 2015 - 04:04 PM
Posted 24 October 2015 - 10:47 PM
Posted 25 October 2015 - 09:24 AM
Not always...No drilling needed. Screw a 100mm wood screw in to the middle, grab with pliers or a claw hammer and it'll come straight out.
Posted 03 November 2015 - 09:50 AM
I ended up drilling, hammering and used a chisel took me about 2hrs
Posted 11 November 2015 - 09:22 PM
