Afr Gauge Saying Running Lean
Posted 25 October 2015 - 08:04 PM
Posted 25 October 2015 - 08:08 PM
Is the censor ok apprently the pre cat ones can failNot sure if it's a problem with my gauge but it is showing full LEAN 100% of the time. Not sure if it's a coincidence but took the car out, on starting and the first 5 minutes the Afr gauge was giving good readings showing lean when off the throttle and then when applying power and driving with a level throttle it was going to 14ish, which is right. Then it went to staying on lean. I had been mucking around with the traction control and one collection of settings caused the car to have too many misfire cuts to be undrivable so put the settings back to regular. Probably just a coincidence that the two happened around the same time and not related? Is my AFR gauge knackered or is my car really running lean - which worries me big time!
Edited by Kieran McC, 25 October 2015 - 08:09 PM.
Posted 25 October 2015 - 08:21 PM
Edited by dw1, 25 October 2015 - 08:21 PM.
Posted 25 October 2015 - 09:25 PM
Posted 26 October 2015 - 07:13 AM
What sensor/gauge are you using?
Posted 26 October 2015 - 08:13 AM
1. Check exhaust joints (particularily the 3.25 inch V-band one).
2. Swap out the 2 lambda sensors with genuine Bosche (OEM) ones (don't be fooled by eBay copies).
Good luck.
Posted 26 October 2015 - 11:16 AM
Maybe a tiny one, but it the exhaust note sounds normal.Is it possible you have a hole in your exhaust ??
It's a PLX DM6 gauge. Has worked well in the past and I have logs of it on my vbox as a channel.What sensor/gauge are you using?
It should have Bosche OEM sensors. Does it sound more like a gauge/sensor issue than the car really is running lean? It's the latter that really worries me as it could shag my engine. Are there any other symptoms to tell if it is running lean?1. Check exhaust joints (particularily the 3.25 inch V-band one). 2. Swap out the 2 lambda sensors with genuine Bosche (OEM) ones (don't be fooled by eBay copies). Good luck.
Edited by dw1, 26 October 2015 - 11:17 AM.
Posted 26 October 2015 - 11:34 AM
It will drive like sh*t, or not run at all if it was running that lean. And you probably get an EML from the OEM O2 sensor that something is not right.
Did you check the WB sensor's reading in free air, or do a free air calibration if possible?
Posted 28 October 2015 - 05:23 PM
Posted 28 October 2015 - 05:34 PM
Posted 28 October 2015 - 05:50 PM
Posted 28 October 2015 - 06:27 PM
Posted 28 October 2015 - 06:30 PM
Edited by CHILL Gone DUTCH, 28 October 2015 - 06:32 PM.
Posted 28 October 2015 - 06:42 PM
Posted 28 October 2015 - 07:22 PM
the reading might be a default reading while the lambda is heating up
if your 100% on your wiring and
100% the exhaust is not blowing
can you turn the TC off completely and see what effect that has
Posted 28 October 2015 - 07:34 PM
Troubleshooting:
Upon power up, the WB analog output should read 2.30V-2.40V with the O2 sensor disconnected. With the O2 sensor connected and exposed to free air, the WB analog output should read starting from 2.3V climbing up to 5.0V within 30 seconds. If both conditions are met, your SM-AFR is properly working. If the sensor does not reach Lean/Air within 45-60 seconds, please replace your O2 sensor. Replacement sensors are available from the PLX Online Store under accessories.
1. The output is not showing the correct AFR readings:
A. With the O2 sensor harness disconnected, at initial power-up it should display between 14.6 and 14.7 (wideband analog voltage: 2.30V - 2.40V).
i. If it is reading below 14.5, please verify that the unit is receiving at least 12V and you have at least a 5 amp fuse. If it is still reading below 14.5 even with the correct voltage, contact rma@plxdevices.com and request a RMA number. Your unit is faulty and needs to be repaired.
ii. If it is reading above 14.8, contact rma@plxdevices.com and request a RMA number. Your unit is faulty and needs to be repaired.
B. Reconnect the O2 sensor with the sensor harness, with the O2 sensor exposed to free air. During the 30 second warm up phase, the voltage should increase from 2.35V to 5.0V.
i. Voltage does not read 5.0V even after 60 seconds:
a. Try another power source for your SM-AFR.
b. Verify that a fuse is installed rated no less than 5A.
c. Check connectivity of harness and O2 sensor.
d. Your O2 sensor needs to be replaced.
C. When the unit says AIR*, blow on the O2 sensor. The display should show LEAN*.
i. Display does not go to LEAN*:
a. Your O2 sensor needs to be replaced.
* will only show “LEAN” or “AIR” on DM-6 Gauge
