Flywheel And Clutch Questions
5 replies to this topic
#1 sford
sford
  • 1,459 posts
Posted 29 October 2015 - 03:15 PM
I'm going through the process of changing to a lightweight flywheel and new clutch but wondered what bolts I needed. Specifically the fly wheel bolts, EP mention ARP ones however can't find them on the site. Went on the ARP site and they aren't listed specifically for the z22se. I presume these ones hold the flywheel to the crank. I also have some bolt threads sticking out from the outer part of the flywheel which appear on other installs I've seen to have brass coloured nuts on them, where do I get these?
I've got Nev's guide which looks to cover the entire process pretty well. I am planning to get all of the parts together before carry out the work.
Thanks in advance.
Tom
#2 vocky
Posted 29 October 2015 - 03:19 PM
get some thread locking compound and re-use the original crank bolts, the outer clutch cover needs M8 nuts and three holes need enlarging to 8.0mm
http://www.halfords....te-threadlocker
http://www.ebay.co.u...gsAAOSwr81UO9nw
#3 tommobot
tommobot
  • 1,008 posts
Posted 29 October 2015 - 03:30 PM
I got new bolts for the flywheel from Vauxhall directly, from what I remember they weren't very expensive
#4 Rosssco
Rosssco
  • 4,185 posts
Posted 29 October 2015 - 04:23 PM
Not sure why you need ARP bolts? Unless you're running extreme engine torque and a very strong clutch..
#5 sford
sford
  • 1,459 posts
Posted 29 October 2015 - 04:45 PM
EP website said to.
Thanks for all the pointers guys.
#6 CHILL Gone DUTCH
Posted 29 October 2015 - 06:12 PM
There cheap enough ffom Vauxhall
