Hi Everyone, I´m looking to do a get my car SFRO inspected during the spring. (SFRO is a independet kind of MOT here in sweden that approves newbuilt or rebuilt vehicals) Anyone to get my car approved I need to do 2 of each other independent major upgrades, means power train is one (engine and gerarbox), chassi is one, brake system is one and
suspension is one.
I also want to put in least amont of money and hours. since I have 2 kids and spent to many hours the last 5 years renovating the house and fixed my car.
Power train is alread done.
So I have looked into changing the spindles but this isn´t enought I need to make new control arms with new suspension geometry.
Chassi could be one where I have thought about elongating the car with about 10cm and tilt the engine forward.
To get a less nervous car wth more weight over front. But this seems to need a lot of hours.
So I´m quite satisfied with my brakes today but this is also an option here the criteria is, increase disc area with atleast
20% and pad area with 20% or instead of pad area upgrade caliper to a caliper with more pistons.
If I go for brakes the front seems rather easy. I found discs at Reyland.co.uk in size 315*28 since I want to go for 16" front wheels. I´d prefer a 25mm brake disc but I think 28 should be OK. This with a Wilwood Dynalite front caliper.
With these calipers you can vary the size of the pistons.
But rear seems harder, my idea was to fit front caliper in rear and keeping the caliper I have today but this seems like a heavy solution and I don´t know how to space oem calipers out for a bigger disc?
It could also be necessary to change for a new master brake cylinder. I have red that Subaru have someone that fit.
From which Subaru and how much bigger is this master valve, thinking of recalculate front pistons size.
Any ideas?
Br,Per
