2001 Vx220 Front Bonnet Release Handle And Cable
11 replies to this topic
#1 garywhitaker
garywhitaker
  • 14 posts
Posted 17 November 2015 - 06:56 PM
Hello I would be very grateful about replacing my front Bonnet handle and cable as mine has just broken (heavy handed). is it a Vauxhall part do Astra,vectra or corsa fit.some look very similar, my car is a 2001 NA' the bonnet is shut tight at present I just have the cable with the little ball snapped off.All information would be greatly received can I fix it myself?
Many Thanks
Gary
#2 Tony
Tony
  • 1,125 posts
  • Interests:Cars, Railways, Photography, DIY
Posted 17 November 2015 - 09:49 PM
Hi Gary, It's been a while since I crawled under the dash, but would doubt if it's a standard vauxhall part. If I remember the bracket is just a little bit of bent aluminum. Looking inside the bonnet, mine seems to be more like a cycle brake cable so you may be able to get something from a cycle shop if you just need the cable.I suppose the cable itself could be Vxl As for opening the bonnet, can you get a pair of pliers on the inner cable, and pull it to open it. Getting an accomplice to press gently down on the bonnet whilst you are doing it, may relieve the pressure on the spring. HTH Tony
Edited by Tony, 17 November 2015 - 09:52 PM.
#3 techieboy
Posted 17 November 2015 - 09:57 PM
Got fed up with the handle of mine popping out of the bracket whenever you looked at it and replaced it with an off the shelf bonnet release cable with a T handle on it from Car Builder solutions. Works much better and you pull it towards you like any other car now.
#4 smiley
Posted 17 November 2015 - 10:12 PM
:happy:
#5 techieboy
Posted 17 November 2015 - 10:18 PM
Yup, similar type of thing to that though somewhat less intrusive. :wacko:
#6 The Batman
Posted 17 November 2015 - 10:19 PM
cable tie it in place!
#7 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 17 November 2015 - 11:13 PM
Do you have to run a new cable to do this mod, or is the original cable long enough?
#8 FLD
Posted 18 November 2015 - 07:49 AM
:happy:
That was the Vauxhall 'fix' for when they broke my handle off.  Heel, toe, bonnet?  Cowboys.
#9 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 18 November 2015 - 08:14 AM
Looks like it could catch your leg! Just wondered if you could keep the original cable.
#10 FLD
Posted 18 November 2015 - 08:23 AM
Yeah, it was a bit dodgy.  I ended up buying an alloy bracket and new cable from Douglas Valley as I wasn't happy with that.
#11 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 18 November 2015 - 08:37 AM
Looks like they used what ever was laying around the workshop.
#12 FLD
Posted 18 November 2015 - 08:47 AM
Thats an elise S1 cable and bracket, just fitted without thought.
