Dutch Software
80 replies to this topic
#21 vocky
Posted 30 November 2015 - 05:36 PM
The 68mm works fine but gives no extra power over the 65mm and also felt a little less responsive in my application.
Cheers; does the 65mm require any adapting to fit? At least with the software, if i do step up to the 68mm (for SCing) then it is only a tweak of parameters.
straight swap with a 58mm TB and a very good mod - but you will need the Dutch SW to make it work thumbsup
#22 smiley
Posted 30 November 2015 - 06:15 PM
Obdtuner 1.3 only supports 58 and 65mm TB.
Edited by smiley, 30 November 2015 - 06:15 PM.
#23 myles
myles
    Sausagefest
  • 2,093 posts
Posted 30 November 2015 - 09:08 PM
Will this do for the mapping interface? http://m.ebay.co.uk/...1&ul_noapp=true
#24 CHILL Gone DUTCH
Posted 30 November 2015 - 09:20 PM
i have a dell venue pro for mine and have to be honest i wouldent want anything any smaller
#25 myles
myles
    Sausagefest
  • 2,093 posts
Posted 30 November 2015 - 09:22 PM
A normal lappy running windows 7 then?
#26 myles
myles
    Sausagefest
  • 2,093 posts
Posted 30 November 2015 - 09:25 PM
Just had a look at obdtuner.com. I'll be good with my laptop I reckon.
#27 CHILL Gone DUTCH
Posted 30 November 2015 - 09:28 PM
laptops work perfect
just a PITA to do log files with a laptop on your passenger seat
#28 myles
myles
    Sausagefest
  • 2,093 posts
Posted 30 November 2015 - 09:33 PM
True, they aren't being done whilst driving though (if my memories of live mapping are correct). I think I'll get hold of a 65mm TB before I go for the software. I need to start searching!
#29 smiley
Posted 30 November 2015 - 09:57 PM
In my opinion the real gain is in the 2.4 manifold, and not so much in the 65mm TB.
#30 oakmere
oakmere
  • 2,143 posts
Posted 30 November 2015 - 10:44 PM
I think Peter go about an extra 4-5 Bhp with the 65mm TB with similar mods to yours. The manifold and remap are what give the most power but it is nice to Finnish it off with the correct TB. You can always sell it on with the manifold if you go SC at a later date 👍
#31 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 30 November 2015 - 10:48 PM
EFA
You can always sell it on with the manifold WHEN you go SC at a later date 👍
#32 smiley
Posted 30 November 2015 - 10:49 PM
Or SC it with the 65mm, in case you can't find an M62 with the 68mm TB.
#33 siztenboots
Posted 01 December 2015 - 09:10 AM
56mm tb flows enough for 400+ on a turbo. Stick with original.
#34 oakmere
oakmere
  • 2,143 posts
Posted 01 December 2015 - 06:52 PM
Don't think you can compare N/A to turbo it dose flow better on a modified 2.2 and was oem on the 2.4 which produces 170-180 Bhp.
#35 myles
myles
    Sausagefest
  • 2,093 posts
Posted 01 December 2015 - 07:34 PM
Still searching for one, but I have a contact in the US and A so I'll see what he can do.
#36 NDT
NDT
  • 351 posts
Posted 02 December 2015 - 07:50 PM
If this isn't a stupid question... Is this NA only?
#37 smiley
Posted 02 December 2015 - 08:04 PM
No, it also works on supercharged and turbocharged converted Z22SE (NA) engines.
The software ONLY works specifically with the ecu for that specific engine type.
So version 1.3 for NA engines, and it´s currently at version 2.7.7 for SC and turbocharged engines.
#38 oakmere
oakmere
  • 2,143 posts
Posted 02 December 2015 - 08:26 PM
Just so Smiley dosn't confuse people all versions of the OBD Tuner work with an N/A engine. I use the latest version of version 2 and will convert to version 3 when available. The Speed Density mode of version 2 works well with N/A as well.
#39 myles
myles
    Sausagefest
  • 2,093 posts
Posted 07 December 2015 - 12:45 PM
I've got hold of a 65mm throttle body from the States (well, bought it anyway) so I'm in! I'll get the cash all in one account then speak to Peter to arrange to have the ECU flashed.
#40 myles
myles
    Sausagefest
  • 2,093 posts
Posted 07 December 2015 - 10:03 PM
Anyone got a link to an elm327 cable that actually works please?
