Balance Deletion Kit And Under Drive Pulley
Posted 11 December 2015 - 02:35 PM
Posted 11 December 2015 - 04:23 PM
Posted 11 December 2015 - 05:48 PM
Posted 11 December 2015 - 06:11 PM
Posted 11 December 2015 - 08:13 PM
Posted 11 December 2015 - 08:24 PM
No worries
Posted 12 December 2015 - 07:54 AM
Posted 12 December 2015 - 05:13 PM
In case you are interested, the kit can be self sourced, the ladder is off an X20XEV engine as is the new oil pickup pipe. Both can be bought for about £10 from a second hand engine. The grub screws to block the oil channels can be bought for pence.
When you replace the strengthening ladder, it is possible to fit new 12.9 bolts (as opposed to the OEM 8.8 bolts or what ever they are). These allow you to apply more torque to the ladder and clamp it more firmly - a good idea for > 300 BHP engines. At the same time you can also replace the crank cap bolts with similar.
HTH
Edited by Nev, 12 December 2015 - 05:16 PM.
Posted 12 December 2015 - 05:44 PM
Posted 12 December 2015 - 09:25 PM
I supply the deletion kit new, LEH oil pick up pipe, o ring, reinforcement frame, baffle, grubs screws and 12.9 grade cap head bolts of the correct lengths.
Other suppliers supply the low quality GM LEH bolts which on some of the bolt hole are too short because of the counterbalance shafts mounted on dowels so you loose the first 4mm of thread in the block £155 with UK delivery.
Steve
Posted 13 December 2015 - 06:50 AM
Posted 13 December 2015 - 11:30 AM
Or you keep the oil pickup and extend the support legs. For example by using the legs from the donor engine.
As Nev has also said you can build it on the cheap, give the oil pickup a good clean if buying 2nd hand
DG
Posted 15 December 2015 - 08:26 AM
http://www.courtenay...r/prod_337.html Courtenay also provide the correct length / spec bolts etc £148.80 excluding any diacound sure postage is £10 iirc As Nev has also said you can build it on the cheap, give the oil pickup a good clean if buying 2nd hand Don't forget to include cost of gasket set, autovaux tend to be a cheaper oem option and oil and filter DG
That kit is supplied with the low quality original GM LEH bolts which are not suitable for the ZLET engine, if you use them you will pull the thread from the two dowel holes which the counter balance shafts located on.
Steve
