If you wanted to make your own side mount then the vectra adaptor might be a little simpler because it is taller than the Astra version, thus the DIY mount would be shorter and more flat.
M32 Europa Gearbox Mount
#21
Posted 11 January 2016 - 03:38 PM
#22
Posted 07 March 2016 - 02:45 PM
fyi, i finally got my hands on a set of Europa mounts, and on first look, its really not a whole lot different to a how a Corsa VXR gearbox mount, mated to a std F23 VX220 mount looks
the holes dont line up exactly 100% between the VXR gearbox side, and the F23/VX220 side, but its pretty damn close, and only a matter of elongating a hole here and there (and not my more than a few mm)
ill dummy it up properly this evening and measure the heights/offsets, but its pretty damn close from first impressions
#23
Posted 07 March 2016 - 04:08 PM
it won't fit, you need the astra vxr adaptor which is £20 or so from the dealers
#24
Posted 07 March 2016 - 05:25 PM
im not sure youre following what i have in mind
#25
Posted 07 March 2016 - 05:56 PM
you are thinking that the corsa adaptor mount and the F23 vx220 side mount can somehow work together, they don't
#26
Posted 07 March 2016 - 08:17 PM
going to have to disagree for the time being
didnt get a chance to properly measure the offsets tonight, but theyre soooo close its not funny. heights are identical, reach looks identical, fore/aft offset looks within 5mm. ive had retail 'performance parts' that have looked worse/required more work to fit
the 3-hole mount patterns between Corsa M32 and the VX F23 are within 1-2mm overall, and considering that the corsa has something like M12(!) fasteners, the F23 mount holes would need to be milled out to size regardless (for which there is miles of room/meat)... so theres heaps of scope to fine-adjust the exact end position of the F23 chassis-side mounting hole.
plus the F23 alloy mount is about 1/3 of the weight
ill jig it up tomorrow
#27
Posted 08 March 2016 - 08:51 PM
#28
Posted 08 March 2016 - 09:45 PM
Hi Ed,
Could you put some photos up please.
Very interesting.
#29
Posted 09 March 2016 - 09:07 AM
#30
Posted 09 March 2016 - 09:37 AM
you do not need to change the z22se alloy engine mount, the steel version shown is for the z20let engine.
#31
Posted 09 March 2016 - 09:41 AM
yeah, i realise that, I received it all regardless when i bought the gearbox mount, so took a photo of whats there for 1:1 comparison
Edited by ed.oates, 09 March 2016 - 09:41 AM.
#32
Posted 09 March 2016 - 01:38 PM
PS, Neil, youve got the original rear gearbox mount on yours dont you (Europa part, but not lotus specific)?
dont suppose you know/can see if theres a part number in the casting/stamped on it?
its gotta come from somewhere (other than lotus - who presently dont have it) but figuring out where is a challenge!
#33
Posted 14 March 2016 - 09:42 PM
#34
Posted 14 March 2016 - 09:45 PM
#35
Posted 14 March 2016 - 10:11 PM
i had a hunch it might not be - given its a cast alloy part (very large manufacturer OEM style) and other lotus ad-hoc solutions were welded steel
#36
Posted 15 March 2016 - 06:20 AM
#37
Posted 15 March 2016 - 06:17 PM
#38
Posted 15 March 2016 - 06:56 PM
not unthinkable (am considering casting the upper gearbox mount)
this rear gearbox mount though... not exactly growing on trees
#39
Posted 15 March 2016 - 08:57 PM
#40
Posted 24 June 2017 - 03:19 PM
