Zlet Drive Belt Tension Pulley Torx Bolt Rounded, Any Tips?
17 replies to this topic
#1 MattyJ
MattyJ
  • 55 posts
Posted 04 January 2016 - 04:35 PM
hi all,
I am trying to change the cam belt on my 2006 tubby. I have got as far as far as trying to slacken the tensioner pulley by freeing the torx bolt. Even with the correct torx socket the bolt hasn't budged but instead rounded the torx bolt teeth. I can't believe in Vauxhalls infinite wisdom they used a torx bolt instead of a standard bolt in such a location. Has anyone had this issue before with this bolt? If so how did you get the bolt and therefore the tensioner pulley out?
Attached File  Capture.gif   224.6KB   7 downloads
#2 D-DAWG83
D-DAWG83
  • 1,276 posts
Posted 04 January 2016 - 04:42 PM
Im guessing you have tried to smash on a slightly larger torx bit.
#3 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 04 January 2016 - 05:16 PM
Hammer in a bigger torx bit. File some flats on 2 sides and use some grips.
#4 MattyJ
MattyJ
  • 55 posts
Posted 04 January 2016 - 07:05 PM
Yep tried this. The engines still in the car so there's not much room to get a good smashing hammer angle
#5 MattyJ
MattyJ
  • 55 posts
Posted 04 January 2016 - 07:11 PM
Will try and file the sides off the bolt. It's just with the semi circle shape of the bolt there's not much grab available to grip. Such a crazy bolt to use here.
#6 GaryK
GaryK
  • 168 posts
Posted 04 January 2016 - 07:24 PM
If you have a dremel, you could cut across the bolt to cut the washer out from underneath.
#7 Nev
Posted 04 January 2016 - 07:49 PM
Jeeze, nasty problem. Best of luck.
#8 Kieran McC
Kieran McC
  • 3,416 posts
Posted 04 January 2016 - 07:58 PM
Flatten the sides and a set of grips
#9 hairy
hairy
    Moonlander
  • 6,064 posts
Posted 04 January 2016 - 08:38 PM
Dremel with deburring tool to grind the top off.
#10 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 04 January 2016 - 08:53 PM
All of the above work, you could try hitting the metal adjustment part with select big flat screw driver and hammer to hopefully loosen the bolt initially I have selection of bolt removing bits and they have worked even on the domed heads Also different torx sockets over the years vary and a decent one can usually do the trick Its either been way over tightened and or bit seized DG
#11 Zoobeef
Zoobeef
  • 11,103 posts
Posted 04 January 2016 - 09:24 PM
Another way is a hammer and chisel, make a notch then knock it round.
#12 ciderbooze
ciderbooze
  • 1,227 posts
Posted 04 January 2016 - 09:58 PM
A centre punch also works.
#13 stu8v
stu8v
  • 745 posts
Posted 04 January 2016 - 10:35 PM
Weld a nut on it. 👍
#14 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 05 January 2016 - 07:10 AM
This way works well ;)
#15 siztenboots
Posted 05 January 2016 - 07:30 AM
Some are 13mm head m8x50mm, spec must have changed to torx bolt but they round out easy.
#16 MattyJ
MattyJ
  • 55 posts
Posted 05 January 2016 - 10:42 AM
Once I get it sorted I will be replacing with a proper standard bolt, thanks for the size spec.
#17 MattyJ
MattyJ
  • 55 posts
Posted 06 January 2016 - 09:35 AM
Attached File  Capture_bolt.GIF   34.04KB   4 downloads
Sorted!
Thanks for all the tips. I used my dremel with cutter disk to make a slot at the best angle to then hammer against the largest flat head screwdriver I have. I repeated this process multiple times to loosen the bolt. After a about 3-4 turns I was able to get an 18mm socket over it to ratchet it out.
#18 Nev
Posted 15 January 2016 - 12:30 PM
Crikey, what a pic !
