Passenger Seat Removal And Sill Cover
Posted 11 January 2016 - 08:59 PM
Posted 11 January 2016 - 09:02 PM
Seat out would be easier but it can be done with a stubby screwdriver and a lot of patience
Posted 12 January 2016 - 07:42 AM
Posted 12 January 2016 - 08:08 AM
Too true. I glued a hex bit into a ratchet ring spanner.You will love 'that bolt' ....
Posted 12 January 2016 - 08:33 AM
The lotus motorsport seats no longer have issues with that bolt due to design.
Bit of an expensive workaround though.
Posted 12 January 2016 - 10:11 AM
I'd recommend a magnet for when you drop bolts down the back of the seat
Posted 12 January 2016 - 10:20 AM
Posted 12 January 2016 - 11:40 AM
There is a knack, start by getting the 3 easy bolts just 2 turns in. Then tilt the seat back and drop the last bolt in and then lower down. I use a ratchet ring spanner and hex bit arrangement to get the bolt to turn. Make sure the threads are clean though or you'll not get the bolt to bite or worse cross thread it.
Posted 12 January 2016 - 05:09 PM
Hi, thank you for the responses, however can I ask two fundamental questions
1) Are the seat retainer nuts captive ie: they are not going to drop into the pan when I remove the bolts
2) I am guessing now that the seats doesnt need to be removed however there are two challenges 1) Removing one of the seat bolts and 2) Removing the rearmost fixing of the sill without removing the seat
Anyone West Midlands based, with the tool and a passion for beer?
Posted 12 January 2016 - 05:21 PM
1) No, these are in the floor chassis
2) Drivers seat is easy to remove, 4 bolts.
Pax 3 bolts easy, 1 front left is the mission if you don't have a short tool for the job.
Much better to remove both, then you have full access if you wish to remove speaker panel
Posted 12 January 2016 - 05:24 PM
Photo found in google images
Posted 12 January 2016 - 05:26 PM
Sills come out withOUT removing the seat... well mine do..lol
You might find the stuck down from the factory, so watch out you don't snap them
Posted 12 January 2016 - 07:16 PM
Posted 12 January 2016 - 08:40 PM
