Sports Cat Or Not?
16 replies to this topic
#1 Georgeralph43
Georgeralph43
  • 344 posts
Posted 21 January 2016 - 08:37 AM
Hi guys Is it worth getting a sports cat downpipe or not? Would love a de-cat but I want the car to remain MOT legal as do European trips a fair bit not just track.
#2 smiley
Posted 21 January 2016 - 08:45 AM
What are you trying to achive? Noise or performance?
#3 Georgeralph43
Georgeralph43
  • 344 posts
Posted 21 January 2016 - 08:47 AM
Oh only performance. Felt it may allow the turbo a bit of freedom.
#4 smiley
Posted 21 January 2016 - 08:55 AM
I´m not into turbo´s, so wait for someone else to step in.
It would help if you can describe the current mods on your car (if any), where you are now on bhp, and where you would like to be.
That helps us in explaining better where the money should go, and how to achieve where you want tot go.
#5 turbo boy
turbo boy
  • 1,161 posts
  • Interests:Cars, fitness, fishing, sports
Posted 21 January 2016 - 04:37 PM
Car George, I presume you are referring to the main cat and not the pre-cat? If so, I have a 100 cell cat on my system. I have to go to a friendly MOT station to get it through the test and it also has to be very hot before the emissions test.... So consider carefully. Jon
#6 Ivor
Ivor
  • 2,189 posts
  • Interests:Sheep & Ducatis
    and now bees
Posted 21 January 2016 - 05:17 PM
Take the precat out,its not needed for mots. Get a removable main cat, put in for mot take out for the rest of the year :)
#7 Georgeralph43
Georgeralph43
  • 344 posts
Posted 21 January 2016 - 08:32 PM
oh so the pre-cat doesnt matter - i.e. I could get a straight through on the downpipe?
#8 hairy
hairy
    Moonlander
  • 6,038 posts
Posted 21 January 2016 - 08:42 PM
I have removed pre-cat, MOTs no problem.
#9 TFD
TFD
  • 607 posts
Posted 21 January 2016 - 09:33 PM
No backpressure is best for the turbo. I run a 3" 200cpi metal cat to pass MOT, reduce noise a bit and save some trees on the long run. I'll up the boost a bit to compensate for the lost horses if needed.
#10 NDT
NDT
  • 351 posts
Posted 22 January 2016 - 11:58 AM
Pre cat removal makes a big difference to turbo response. People say it'll give you some power too through reduced back pressure (don't know, haven't measured) but for me it was worth it for the big improvement in low speed response.
#11 Georgeralph43
Georgeralph43
  • 344 posts
Posted 22 January 2016 - 02:38 PM
Very useful guys thanks.
#12 smiley
Posted 22 January 2016 - 02:54 PM
Keep in mind that above advice is not answering your initial quest for performance.
You could be out spending 500 pounds on a 5 bhp gain.
Again. List what you have on mods and where you want to go. Otherwise people here will be very helpful in emptying your wallet, and you may end up disappointed in where you are.
#13 Tibbles Stryker
Tibbles Stryker
  • 1,941 posts
Posted 22 January 2016 - 04:34 PM
I thought if we didn't produce a bit of back pressure then it shagged the turbo? I'd like a de cat.
#14 anz3001
anz3001
  • 1,617 posts
Posted 22 January 2016 - 04:42 PM
Remove pre cat altogether - no mot issue.
200 cell sports cat, almost as good performance as a full de cat and will have no issues with MOT, although expensive and still prone to melting particularly on SC'd cars (can be off set by buying a better quality unit although some research will be required)
100 cell sports cat - hardly worth the effort, equally and sometimes more expensive than a 200 cell for little to no gain and a twat to get through MOTs anyway.
De cat - Cheap, no restriction, no melting although need an avenue for MOT's, either a dodgy tester or bolt your o.e back in. Rumours the standard turbo seals don't like a complete lack of back pressure.
#15 Tibbles Stryker
Tibbles Stryker
  • 1,941 posts
Posted 22 January 2016 - 04:45 PM
But only for the chav effect 👍
#16 TFD
TFD
  • 607 posts
Posted 22 January 2016 - 10:48 PM
The less the better.
Get a METAL cat! The ceramic will blow (as used by expensive exhaust builders and were SC guys seem to melt/blow them out).
Running a 3"200cpi Magnaflow metal cat now. We'll see how that one holds.
#17 Georgeralph43
Georgeralph43
  • 344 posts
Posted 23 January 2016 - 09:34 AM
I have bought a pre cat delete (straight through) so will report back once Matt has fitted it.
