225/45 16 Et15 In Front, Will It Work?
24 replies to this topic
#1 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 31 January 2016 - 03:27 PM
My Wheels I bought didn´t fit over my brake caliper so I´m looking into other options.
So now I´m looking at TDs 1.2 16*7 front which are a bit narrow and I´m thinking about ET 15
with R888 225/45 16 at 110mm ride height front and  1.5-2 deg negative camber.
Will it fit?
Anyone having something similar to  compare with?
And why I´m thinking of ET 15 is because I´m thinking of modify the Wheels later on and at 20mm or so
and then I won´t need so much spacer disc.
Why I´m asking, I want to know what peaople tested and my cars comlete suspension is taken apart.
Thanks, Per
#2 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 31 January 2016 - 09:24 PM
Anyone have a Nice picture of td pro race 1.2 16" ET20 with 205/50 and 110 in ride height?
#3 Tonie Pettersson
Tonie Pettersson
  • 423 posts
Posted 01 February 2016 - 07:03 AM
205/50-16" with TD's. If I remember correct the ride height is 118mm and 2.2° camber.
#4 Jocke_D
Jocke_D
  • 407 posts
Posted 01 February 2016 - 07:18 AM
Here's mine with 7x16 and 205/50 in front (225/45-17 back). Not sure about ET but they are made for the Speedster so probably 20 (?). I have NO idea what so ever avout ride height.
You might have seen it at Kinnekulle last fall. You were there with OSC if I'm not mistaken  :huh:
#5 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 01 February 2016 - 07:48 PM
Thank you.
#6 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 02 February 2016 - 06:03 PM
What do you Think Tonie.
if you measure from the side of the tire to out whel arc and look from above, how many mm do you have.
Do you have 10-15mm extra space?
#7 Tonie Pettersson
Tonie Pettersson
  • 423 posts
Posted 03 February 2016 - 08:08 AM
I´ll check as soon as I get home from work.
#8 Nev
Posted 04 February 2016 - 03:51 PM
I have 18" x 245mm (ET14) with 30% profile tyres and -0.5 degrees negative camber on the front of mine. I get bad rubbage at both left/right near full lock. It is a problem that you can just "steer" around IMO unless you do a lot of parking and town driving.
Edited by Nev, 04 February 2016 - 03:54 PM.
#9 Tonie Pettersson
Tonie Pettersson
  • 423 posts
Posted 05 February 2016 - 06:56 AM
Seems I forgot to measure...
I´ll try to remember it this weekend.
#10 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 05 February 2016 - 06:59 PM
Thanks for the input Nev, but this is just a "parking" problem? Do you feel any negative handling problems with it? The idé is that I might widen the wheels in the future and then I wont need as much spacer. And I want a wide foot print. Br, Per
Edited by Aerodynamic, 05 February 2016 - 06:59 PM.
#11 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 05 February 2016 - 07:05 PM
Thanks Tonie, appreciate that. Br, Per
Seems I forgot to measure... I´ll try to remember it this weekend.
#12 Nev
Posted 05 February 2016 - 08:28 PM
It's never a problem when driving as the steering input is never severe like parking (ie once over 30 #mph you never turn full lockon unless you are a lunatic!). You may need to make some adjustments to the plastic wheel arch liners, as mine are worn through in several places where the wheels have rubbed over the years. To me this is insignificant but some might be worried by such minor things.
#13 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 05 February 2016 - 08:57 PM
I was not just thinking about wheel touchen the arcs. I was more thinking of if you get different behaviour when cornering or the car feeling nervouse because of low ET in the front or strange tire wear? Br , Per
#14 Nev
Posted 05 February 2016 - 09:04 PM
My front feels different to a normal VX, it's hard to express really. It feels heavier to me, and less responsive to very rapid angle changes that only occur in tight slalom situations (has happened to me on a very tight track 1 time for me so far). On the positive side I have more grip/security, everyone who has driven it has said so. My centre of turn radius is no longer near the centre line of the tire and I think this makes the steering quite a lot more twitchy. It road-rails more on motorway lorry tyre depressions a lot more.
Edited by Nev, 05 February 2016 - 09:06 PM.
#15 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 06 February 2016 - 06:23 AM
Et 15 is not that much different from std. Couldn't it be that your heavier wheels are the most different in steering feel, less responsive? Ok but its worth trying then.
#16 Nev
Posted 06 February 2016 - 04:07 PM
Yes my floating mass on the front wheels has increased a lot, something like +7.5 Kg per corner (from memory).
It's a shame you can't "pop over" and drive it, that way you'd understand better. Also, I forget now how a standard VX220 feels, hardly anyone has a standard car to drive any more !
Edited by Nev, 06 February 2016 - 04:08 PM.
#17 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 09 February 2016 - 05:10 PM
Any updates Tonie? Br, Per
#18 siztenboots
Posted 09 February 2016 - 05:17 PM
I run the lightest tyre / wheel combo that I can , with a 205/45/16 tyre, from memory my front is ET20 without any rubbing.
#19 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 09 February 2016 - 07:05 PM
But how much do you have from tire sideways to fender if you look from above? Br, Per
#20 siztenboots
Posted 09 February 2016 - 07:09 PM
best pic I have
