Hi Guys
Suspect alternator issues, my battery light came on whilst on-route to work, this was shortly after replacing
As i got closer 20mile trip, all dash lights started to come on (battery draining i take it)
Ive checked the alternator belt and its still there, I able to borrow a volt metre to check the battery terminals on sunday, would the following work for me to identify if the alternator is at fault
-1 jump start car, remove battery connections from battery at this point the car should stay ticking over as its getting power from the alternator, if screwed, the engine will die.
Is there any know cable issues that i need to check before replacing the alternator, any other tests?
Next Qs worst case alternator replacement is it a diy job? ive been trying to find a guide for a turbo, not having much luck....from what ive read easiest way, remove rear wheel and arch liner gain access through this route.
If i need to replace it will be done in the cold in my work car park, is it a fairly easy job, im not great with spanner, however as kid replaced countless alternators and starter motor on all of my dads fords, however those cortina's had load of space to work in.
Best place to buy a replacement if need?
Cheers for looking
