Materials so far (most have been collecting dust for ages!)
HID kit - purchased 18 months ago!!
Fez light lenses - purchased god knows when on the crowd funder
Primer, and black paint
sharp knife
Sand paper
screwdriver
oven
hair dryer
3M Butyl double sided tape (best I could buy)
PATIENCE!!
A wife to ensure I remain patient and do the fiddly bits with the masking tape!
Step 1 - remove headlights, 45 mins
Passenger side - easy. I replaced with a wing nut last time I took it off
Drivers side - Remove the wheel and wheel arch liner as my charge cooler pipes prevent access to the nut from under the bonnet (Stupid F'ing car!! I cant see that I could change a bulb without taking the wheel off, crazy!)
Step 2 - get old lenses off 1 hour
I think I had a mixture of tape and tiger seal on the lenses, this was a really pain in the arse. The hairdryer method didn't seem to be doing much for me, so I used the oven. I wasn't sure how hot to go, it didn't seem to make much difference, so just slowly until I found a method which suited. I was using a knife to get under the clear covers, but found that prizing them off rather than trying to cut the glue worked best for me.
Lenses don't look too bad in this photo but they are pretty crazed
Step 3 - clean up remaining glue and residue. 1 hour
Just a pain in the arse - but a bit of sand paper and blade to scrape of the residue. A good clean with white spirit before masking up
Step 4 - masking up - 30 mins
Use wife and tape here (not like that!). Small hands work better than mine
Step 5 - Primer . Give them a few coats and leave for 24 hours.
Step 6. Pub. Finish tomorrow hopefully!!
Edited by Alastair, 20 February 2016 - 02:45 PM.
