Hello All
I’ve posted about this issue before, however taken advice from you guys and had someone hook up a diagnostics reader, fault code P1106.
P1106 (01) Boost Presure signal out of range Not D
When the cars experiencing this error, I lose 20-30% power, still boosting however cars not all there and very slow at getting to 4000 revs when pushing the car hard in any gear , no engine management lights present, once I experience the loss of power usually cures itself after a few weeks, I’ve had a flat battery a few times and this has cured/erased the issue (I suspect this resets the error on the ecu)
Car Garage cleared the error this morning after the reading, experienced the issue for the 1st 2 miles then magically cured itself and boosting fine, driven into work with a smile on my face boosting hard no issues, even manged to pissing a off a Evo that couldnt keep up
So its intermittent, has a habit of curing itself, and can clear if I run the battery flat or disconnect the battery, if I drive the car hard before it reaches 82 degrees ive noticed this is when its most likely to throw itself into this error.
Is it a electrical, or mechanical issue, im so lost asking mr Google has had me worried, people out there changing everything from the turbo to sensors and still not getting to the bottom of the fault.
Any ideas guys, your help is most appreciated
Thankyou!
