Reading Fault Codes
9 replies to this topic
#1 Edgeydt50
Edgeydt50
  • 74 posts
Posted 28 February 2016 - 10:19 AM
So my Eml came on yesterday. I plugged in the Bluetooth dangle and got a report from torque. Only thing is that I can't find much information about the codes generated. Is anybody able to make any sense of this. Thanks in advance Vehicle VIN: W0L0EAR97 Vehicle Manufacturer: Unknown Vehicle Calibration ID: 12210633 Current Fault Log ------------------ ECU reports no current faults Pending Fault Log ------------------ ECU reports no pending faults Historic Fault Log ------------------ ECU reports no historic faults Other discovered fault codes (possibly pending, current or manufacturer specific) ---------------------------------------------------- P1137: [BMW] O2 Sensor Heater Circuit Signal Intermittant (Bank 1 Sensor 2) [Chrysler] HO2S Bank 1 Sensor 2 Lean System or Low Voltage [Ford] Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1 [Mazda] HO2S Bank 1 Sensor 2 Not Switching (Fuel Control Limit Reached) [Dodge] HO2S Bank 1 Sensor 2 Lean System or Low Voltage [Jeep] HO2S Bank 1 Sensor 2 Lean System or Low Voltage [Seat/Audi/Volkswagen] Long Term Fuel Trim Add.Fuel,Bank1 System too Rich P0111: Intake Air Temperature Circuit Range/Performance Problem U20BF: Unknown code - More information may be available on the web End of report.
#2 P11 COV
P11 COV
  • 7,686 posts
Posted 28 February 2016 - 10:55 AM
That looks a nice thorough readout...what is device you are using?
#3 Edgeydt50
Edgeydt50
  • 74 posts
Posted 28 February 2016 - 10:56 AM
£5 eBay dongle and torque pro. Great app that I've just started using
#4 techieboy
Posted 28 February 2016 - 11:04 AM
Needlessly thorough. Reporting every other manufacturers description of the P1137 error, other than Vauxhall/Opel. :lol: As per the description's, P1137 is a fault with your rear lambda sensor. Many many threads on here dealing with it. U20BF code is I think Torque not understanding a manufacturer specific code, you might want Op-Com or different fault software to correctly decipher that.
#5 Edgeydt50
Edgeydt50
  • 74 posts
Posted 28 February 2016 - 11:09 AM
Yeah I've read up on p1137.i have opcom too but can't get it to connect so opted for torque. Maybe I'll try a bit harder to get opcom to work
#6 P11 COV
P11 COV
  • 7,686 posts
Posted 28 February 2016 - 09:56 PM
:lol: I had completely missed that all that info was for other models...I thought you VX was in a real bad way!
I use Scanguage which keeps things nice and simple but can't diagnose faults such as ABS which I have needed in the past and need now.
#7 Edgeydt50
Edgeydt50
  • 74 posts
Posted 28 December 2016 - 03:59 PM
sorry to bump an old thread. Can somebody confirm if this is the rear sensor or the front? not sure and wouldn't mind taking advantage of the discount if its correct
#8 Edgeydt50
Edgeydt50
  • 74 posts
Posted 28 December 2016 - 04:32 PM
link would have helped
http://www.eurocarpa...3e6b864b
#9 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 29 December 2016 - 11:57 AM
link would have helped  http://www.eurocarpa...3e6b864b
Go on carparts4less.co.uk and stick your reg in then search for lambdas. When you select which one you want you can also use discount code boxing15 for 15% off too
#10 LY_Scott
LY_Scott
    Formerly LY055SCO
  • 9,221 posts
Posted 30 December 2016 - 02:17 PM
NGK Part is OZA531-GM3
http://www.ngkpartfi...ne=2.2&pos=Rear
80 odd quid online.
