Front Clam Removal Guide
17 replies to this topic
#1 dedposh
dedposh
  • 48 posts
Posted 04 March 2016 - 01:50 PM
Hi,
Has anyone got the PDF guide? All the threads I can find are quite old and the links are dead!
thanks
#2 Potatoes
Potatoes
  • 546 posts
Posted 04 March 2016 - 01:52 PM
Here you go
Edited by Potatoes, 04 March 2016 - 01:53 PM.
#3 chickendippers
chickendippers
  • 488 posts
Posted 04 March 2016 - 03:25 PM
How long does front clam take to get off roughly?
#4 pete-r
pete-r
  • 2,771 posts
Posted 04 March 2016 - 03:31 PM
Did one last weekend took about 2 hours with cutting out some rotten bolts and labelling everything to help put it all back (which you could do in advance with some plastic bags or takeaway containers).
Edited by pete-r, 04 March 2016 - 03:31 PM.
#5 Raptor
Raptor
  • 942 posts
Posted 05 March 2016 - 04:15 PM
Thanks for the guide - I needed one too.  I don't suppose there is a rear one too in pdf?
#6 Hofmiester
Hofmiester
  • 2 posts
Posted 23 April 2018 - 07:22 AM
Awesome, love this forum!
#7 aquilaproejct
aquilaproejct
  • 267 posts
Posted 23 April 2018 - 09:41 AM
Yeah I could do with a rear removal PDF too!
#8 siztenboots
Posted 24 April 2018 - 02:15 PM
the guides are also on the facebook page
https://www.facebook...43368893/files/
#9 Entwistlecymru
Entwistlecymru
  • 9 posts
Posted 13 April 2020 - 02:50 PM
Sorry to dredge up an old subject but I’ve hit a brick wall with removing mine. I knew someone had taken the clam off previously, but the numpty that did it has cross threaded the bolt that goes into the pillar above the door hinge. I’ve removed all other fixings and the door but I cannot get the Allen bolt out. It’s a SS 5mm hex which started to come out but stuck solid after 1 turn and will not budge. I’ve tried every technique I can To get it out but it’s now rounded. Short of cutting the mounting bracket has anyone got any bright ideas please?!
The clam needs repairing due to some previous bodges (not by me!) so a little damage isn’t the end of the world but it would be nice to avoid that. Any ideas appreciated!
#10 The Batman
Posted 13 April 2020 - 04:00 PM
cut bracket, remove clam, drill out bolt, repair bracket.
#11 hairy
hairy
    Moonlander
  • 6,034 posts
Posted 13 April 2020 - 04:08 PM
can you cut the head off the bolt with a dremel?
#12 The Batman
Posted 13 April 2020 - 04:35 PM
if the bolt is slightly removed you can get a hacksaw blade in to cut the bolt
#13 oblomov
oblomov
    oblomov
  • 3,873 posts
  • Interests:Mumblers
Posted 13 April 2020 - 06:20 PM
If you can find something like this
https://www.homedepo..._-300533468-_-N
that's sufficiently compact to fit in the limited space, you could use short drill bits to drill out the bolt head with small then larger bits until the head comes off, then remove clam and then remove bolt.
Other than that, as Batman says.
Edited by oblomov, 13 April 2020 - 06:21 PM.
#14 The Batman
Posted 13 April 2020 - 07:06 PM
doubt you'll get that in there to be honest.
#15 myles
myles
    Sausagefest
  • 2,084 posts
Posted 13 April 2020 - 08:38 PM
If you can get one of these on there; they've always worked for me. (Nut and bolt remover)
https://www.ebay.co....tm/401780628026
#16 Entwistlecymru
Entwistlecymru
  • 9 posts
Posted 13 April 2020 - 10:50 PM
Problem solved. Used my Dremel to cut a slot in the bolt head and managed to use a screwdriver to get it out. 5 hours spent on one bolt because someone got lazy! GRRRR!!!! Clam is off anyway - thanks for the suggestions gents
#17 blackoctagon
blackoctagon
  • 199 posts
Posted 14 April 2020 - 11:04 AM
Just in time for me.
Much appreciated guide, Mr.Crisp.
#18 Foxy_Jr
Foxy_Jr
  • 478 posts
Posted 14 April 2020 - 01:53 PM
Before you put it all back together, carefully run a tap through the captive nuts and apply copper slip to all the bolts. chinky chinky
Speedy Fasteners do complete and various partial kits for the VX.  Worth spending a few quid and stainless looks pretty! :wub:
https://www.speedyfa...ings_s/1513.htm
