Dielectric Grease, Turbo Coil Pack
4 replies to this topic
#1 A-GAME
A-GAME
  • 244 posts
Posted 06 March 2016 - 10:36 AM
Decided to check my plugs for water ingress. One was a little damp so I decided to use some servisol dielectric grease when refitting. I had a spare coil pack to experiment with so read up a little about it on the loutus/ford forums then smeared it on the ceramic part of the plug, a little inside the boot end (but not directly on the contacts) and more liberally around the outer/top of boot shafts to try and create a water-repellent barrier to ingress. What are people's experiences of using this and thoughts? Took it for a blast and all seems well. Cheers
#2 Nev
Posted 06 March 2016 - 11:04 AM
Sensible approach IMO. You can do the same for all the plug sockets/connectors around the engine bay and help keep the gremlins away.
#3 stu8v
stu8v
  • 745 posts
Posted 06 March 2016 - 02:19 PM
I use electrical silicone compound for the same. Dow Corning.
#4 Kieran McC
Kieran McC
  • 3,416 posts
Posted 06 March 2016 - 03:13 PM
Rtv silicone grease works great
#5 A-GAME
A-GAME
  • 244 posts
Posted 06 March 2016 - 05:28 PM
Great. Thx. So it sounds like I've applied it to the correct areas? My mine priority was to keep water out of the coil pack/chambers so I've put plenty near the top of the 4 outer boots where they sit in the holes to try & create a barrier to stop moisture getting in and down the chambers
