Just thought id share!
http://www.ashfordpe...arts-and-labour
As some people know the astra VXR (Z20LEH) has Mahle forged pistons as standard, the biggest factor which prevents the Z20LEH engine making big power is the Rods. These are rated to around 320BHP, anything over this we would highly advise fitting stronger Forged Steel Rods. Once these are fitted along with some uprated valve springs the Z20LEH engine is capable of over 500BHP.
This is a common upgrade and to make things simple this kit is for Ashford Performance Ltd to supply and install all the neccesary parts to install the I Beam rods and uprated valve springs.
Kit contains:
4x Forged I-Beam Rods
4x Rod Bearings
16x Piper upgrated single valve springs
4x Piston Ring Sets
1x Full top end gasket set
1x Full bottom end gasket set
1x Cambelt kit
5 Liters Running in oil and filter
5 Liters Performance oil and filter
1x Water Coolant mix
Installation of all of the above parts including re-seating valves, re-hone bores and gaping the new piston rings
Price: £1,550.00
Shipping:£0.00
