Posted 26 April 2016 - 01:05 PM
Another vote for Henderson Taylor, sub £400 for me (34 years old) with the below mods declared:
Engine & Gearbox
Eaton M62 Supercharger
SC inlet manifold with laminova heat exchangers
LSJ 68mm throttle body
Bosch 470cc fuel injectors
TRE-255 fuel pump
Charge cooling system with Pro Alloy radiator
Iridium spark plugs
Tullet tubular exhaust manifold with pre-cat delete
Tullet 2.5 down pipe with sports cat (200 cell)
De-restricted turbo backbox with 2.5 U bend
Piper stage 2 cam shafts (252° int, 262° exh)
Pro Alloy dual pass radiator
OBD Tuner ECU with custom remap
ECU repositioned to bulkhead
Short shift gear selector
Gearbox breather
Redline MT90 synthetic transmission oil
Pro Alloy 60l anti surge fuel tank
Sequential shift light
6,800rpm rev limit
Approx. 258bhp @ 6158rpm
Approx. 287bhp @ 4681rpm
Brakes
Aftermarket grooved discs (front and rear)
Mintex 1155 pads (front and rear)
Lotus 4-channel ABS unit
Dot 5.1 brake fluid
Braided brake lines
Suspension
Gaz Gold 2 dampers (black bodies)
Gaz springs (front 400lb, rear 450lb)
Titan Quick steering rack
Steering rack riser plates
Eliseparts rear toe links
Eliseparts adjustable anti-roll-bar
Lowered (ride height 126mm front, 132mm rear)
Team Dynamics alloy wheels 17 rear 16 front
Aftermarket rear diffuser
Carbon fibre front splitter
Geometry setup by Blink motorsport
Cosmetic
Carbon fibre door panels
Carbon fibre handle guards
Carbon fibre sills
Carbon fibre sill guards
Carbon fibre dash panels
Carbon fibre centre console
Carbon fibre tunnel cover
Carbon fibre gear stick shaft
Carbon fibre turbo side air vents
Momo gear knob
Momo steering wheel logo
Black powder coated window winders
Black powder coated carpet screws
Black powder coated fuel cap
Black powder coated started button
Black powder coated dash plate
Black powder coated handbrake shroud
Short bee sting aerial
Roll bar headrests removed
High lift bonnet stay
LED sidelights
Aftermarket side repeaters
Chrome indicator bulbs front and rear
Chrome side repeater bulbs
Supercharged ignition coil badge
Audio Equipment
Focal 6 component speakers dash mounted
Sony rear speakers
Sony CD player
Kicker amplifier
JL audio 13 subwoofer in custom fibreglass enclosure
Service/Replaced parts
Wishbones blasted, zinc primed & powder coated
Uprights blasted, zinc primed & powder coated
ABS brackets blasted, zinc primed & powder coated
Damper mounts blasted, zinc primed & powder coated
New seriously lotus ball joints all round (10.2.16)
New seriously lotus bushes all round (10.2.16)
New ARB drop links (10.2.16)
New Lucas wheel bearings (10.2.16)
New snubber washers (10.2.16)
New caster washers (10.2.16)
New 10.8 hub carrier bolts (10.2.16)
New suspension bolts all round (10.2.16)
Geometry setup by Blink motorsport (15/4/16)
