Gel Coat Vs Lacquer
10 replies to this topic
#1 Horace
Horace
  • 1,290 posts
Posted 07 April 2016 - 11:04 AM
Can someone explain to me what the difference is in the painting process for GRP vs metal.
Is the gel coat just a different way of saying the lacquer?
I'm looking around for a decent paintshop, and I want to ask them if they have any experience of painting GRP and sound like I know what I'm talking about.
#2 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 07 April 2016 - 11:12 AM
No gel coat how I understand is part of the fibre glass preparation which makes it fairly smooth And is below primer paint and lacquer
#3 fezzasus
Posted 07 April 2016 - 11:43 AM
As above.
Gel coat is the first layer you put down when molding fibreglass parts, it creates a smooth surface which needs minimal prep.
Note; the automatic process that lotus used for the VX220 parts doesn't have a get coat. They inject a slurry of resin and strand into moulds, then release slightly as they cure to let the resin flow to the surface to smooth.
Main differences between painting fibreglass and metal:
a ) don't want to bake at too high a temperature
b ) some primers might react with fibreglass. Ideally use polyester primer.
Edited by fezzasus, 07 April 2016 - 11:43 AM.
#4 Horace
Horace
  • 1,290 posts
Posted 07 April 2016 - 12:25 PM
So to repair and paint my stone chipped front end, the body shop must:
1. Sand down and remove old flaky paint
2. Fibreglass repair any dents, dings, holes
3.  Apply a gel coat
4. Apply a polyester primer
5. Apply new blue paint
6. Apply lacquer
Have I got it right?
Edited by Horace, 07 April 2016 - 12:25 PM.
#5 techieboy
Posted 07 April 2016 - 12:40 PM
No, no gel coat required. The resin and/or filler they use on the repairs should be sufficient for sanding/priming/painting.
#6 slindborg
Posted 07 April 2016 - 12:48 PM
Gel coat has a habbit of not curing properly if its left to the air (as in it needs ramming into a mold iirc)
#7 fezzasus
Posted 07 April 2016 - 12:56 PM
This.
There's no gel coat on the original bodywork, and gel coat doesn't cure properly in air so no point applying. Just grind out, perform any figerglass repairs, fill and prime with polyester.
#8 Horace
Horace
  • 1,290 posts
Posted 07 April 2016 - 01:16 PM
Thanks guys.
#9 Horace
Horace
  • 1,290 posts
Posted 07 April 2016 - 02:10 PM
So basically, it's the same as doing a fibreglass repair on a metal car, then spraying it
#10 fezzasus
Posted 07 April 2016 - 02:17 PM
Yes.
#11 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    rugby
    eating out
    keeping fit
Posted 07 April 2016 - 04:05 PM
Unles you stone chips are actually blisters which is a different story that someone will clear up for me
