Hi all,
Quick question. I'm relatively new to VX, so haven't encountered the full range of problems yet (so far only popped rad', wheel bearing, leaking lights, bonnet cable stuck, heater cable broke, abs wire broke several times, discs and pads, water in plugs, rocker cover gasket failed ).
From searches I see that failed side engine mounts are generally experienced as grinding noise and clonks when accelerating. I've recently started getting a noise in 1st and 2nd when accelerating hard....but I would describe it as much more like a harsh crackle from behind me, rather than a grinding noise. Does this sound right? And do the side mounts sound different to the front/rear mounts?
Many thanks for any help.
Kev
