Production Of Brake Cooling Kits
24 replies to this topic
#1 Ducati996Senna
Ducati996Senna
  • 815 posts
Posted 26 April 2016 - 03:47 PM
I have had a number of enquiries about the production of brake cooling kits. I can now make these for the following internal diameters:
Std Vauxhall discs of 157mm diameter
EP Bells of 180mm diameter
AP racing Bells of 200mm diameter.
Please email me your orders.
I only sell complete kits and the price is £150 plus postage.
Thanks,
Paul Darby
#2 siobe1
siobe1
  • 135 posts
  • Interests:gym vx trackdays
Posted 26 April 2016 - 04:18 PM
Hi Paul I have sent you a pm, not sure if that's what you meant by email but I would like to buy one I presume these are the same as before that use the fog lamp recess Many thanks Ben
#3 ultimate
ultimate
  • 261 posts
Posted 26 April 2016 - 04:59 PM
Any pics of that kit? Please give us your Email Adress
#4 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 26 April 2016 - 05:11 PM
Upload the pic here please.
#5 alkvalseth
alkvalseth
  • 89 posts
Posted 28 April 2016 - 12:04 PM
Would you make to different size discs as well? I have 308mm EBC Ultimax, they are (according to EBC) Ø182mm.
Thanks,
Andreas
#6 ianrm
ianrm
  • 11,097 posts
Posted 28 April 2016 - 08:30 PM
PM sent
#7 chris_uk
Posted 29 April 2016 - 06:59 AM
Would you make to different size discs as well? I have 308mm EBC Ultimax, they are (according to EBC) Ø182mm.   Thanks, Andreas
Is the opening to the veins on the inside of the disc or the outside? I had a look around and the only 308's i could find which had the vein opening on the inside were very expensive. Obviously any openings on the outside of the disc, ie wheel side isnt going to benefit from these brake cooling mods.
#8 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 29 April 2016 - 11:42 AM
:yeahthat:
Looked all over too and all that I could find had the outboard vents.
#9 redvts
redvts
  • 1,472 posts
Posted 29 April 2016 - 12:38 PM
Cools from the inside.... http://www.vx220.org...ts/#entry936193
#10 chris_uk
Posted 29 April 2016 - 12:45 PM
Correct, hence why you need discs which have the vein opening on the inside not the outside.
#11 redvts
redvts
  • 1,472 posts
Posted 29 April 2016 - 01:25 PM
Sorry, misunderstood, just trying to help
#12 alkvalseth
alkvalseth
  • 89 posts
Posted 02 May 2016 - 09:38 PM
Honestly I haven't checked if the vanes are open all the way from the center and out, I was just assuming that to be true. Are you saying that the vanes doesn't go all the way through? If that's the case, they're ridiculous! I thought I upgraded my the discs! :/
#13 chris_uk
Posted 02 May 2016 - 10:32 PM
They will go all the way throigh, its just whether of not they are open from the outside of the disc or inside of the disc.
#14 alkvalseth
alkvalseth
  • 89 posts
Posted 05 May 2016 - 07:16 AM
I see, thanks for the info Chris. Really wanted these brake coolers.
#15 Jocke_D
Jocke_D
  • 407 posts
Posted 06 May 2016 - 06:26 AM
Have actually never thought about this before. Now I realize that it would obviously make a difference in cooling effect. Any examples of discs (for our cars) that have the opening on the inside?
#16 chris_uk
Posted 06 May 2016 - 06:40 AM
http://www.seriously...ece-curved-vane
#17 alkvalseth
alkvalseth
  • 89 posts
Posted 06 May 2016 - 09:53 PM
Thanks Chris, but those are drilled, and can't have drilled discs since I drive on track, they will crack between the holes..
#18 chris_uk
Posted 07 May 2016 - 06:00 AM
Ive had drilled discs for years and done many trackdays with no cracking between the holes, and im not one to go easy on the brakes either. Infact ive had ebc discs on mine for a couple years now and even they have not cracked and they were cheap. you could look at saab discs.
#19 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 07 May 2016 - 06:50 AM
Pretty sure you will find only those ones at seriously lotus or possibly Tesla discs have the vents on the inside, all the cheap ones, from the GM range are vented from outside on 308mm discs, this includes any aftermarket discs such as EBC or alike which are just patern copies. Even the seriously lotus ones I would check into before buying as they are not cheap for a one piece disc. Lost count of the times I have mentioned this to people, 1st reaction is "no mine are vented from inside" then they go check ;)
Edited by Crabash, 07 May 2016 - 06:54 AM.
#20 ginek
ginek
  • 119 posts
Posted 09 May 2016 - 03:33 PM
Do you find this problem only for 308mm discs? Asking, as I'm still not sure what you mean exactly, simply I see no reason vents wouldn't be opened on both sides of ANY vented disc, on both outer and inner diameter of disc. Otherwise air couldn't get through, effectively they would be not vented.  Prior to your remark my understanding was all vented disc are designed to take air from the inside (bell area) and vent it out. A quick google check on vx220 generic options confirms it (example http://i17.ebayimg.c...6/17/c512_1.JPG - forum doesn't allow to post it as a photo) but I'll still check my past disc iterations.
