What Gauges Do People Have?
26 replies to this topic
#1 siobe1
siobe1
  • 135 posts
  • Interests:gym vx trackdays
Posted 27 April 2016 - 01:19 PM
Hi I have a 2 gauge pod, one for boost (tubby) and was interested in what other people have? Is it more important to have oil temp or pressure if you are tracking the car?? Many thanks for your help Ben
#2 chickendippers
chickendippers
  • 488 posts
Posted 27 April 2016 - 01:23 PM
AFR and boost gauges are the most important in my opinion.
#3 siobe1
siobe1
  • 135 posts
Posted 27 April 2016 - 01:47 PM
Sorry for my ignorance, what's afr?
#4 The Batman
Posted 27 April 2016 - 02:00 PM
Air fuel ratio
#5 techieboy
Posted 27 April 2016 - 02:08 PM
Oil pressure and oil temperature here though I only vaguely monitor oil temps when I'm on track. The rest of the time I pay neither any attention, though it's surprising how long it takes for the oil to get up to normal operating temperatures. :wacko:
Can't see the point of AFR or Boost gauges. AFR changes around too much and means little once a car is tuned properly and boost gauge seem pointless unless you're diagnosing something. If it hasn't got any boost, you'll know about it. :lol:
#6 turbo boy
turbo boy
  • 1,161 posts
  • Interests:Cars, fitness, fishing, sports
Posted 27 April 2016 - 02:15 PM
I went for a boost gauge and a voltmeter - easy to rig up and allows me to track battery charge. But the buchos pod and gauges look awesome in my opinion - with mine it's more aesthetic than functional 👍
#7 smiley
Posted 27 April 2016 - 02:26 PM
I use my cellphone to monitor engine water temp, and SC inlet temp (tmap).
The first as i cannot see the water temp on the regular dash (and killed an engine due to that), and the SC temp warned me early enough when one of my wiring to the chargecooler pump went bust.
I will also be adding the kpa from the map sensor, as that will tell me if the cat went pop, and pressure will go up.
So all based on stuff that can actualy go wrong on track, pulled fom the obd dongle.
Edited by smiley, 27 April 2016 - 02:41 PM.
#8 alexb
alexb
  • 367 posts
Posted 27 April 2016 - 03:57 PM
I've got:
- oil temperature: useful to see when you can finally start hitting the accelarator
- oil pressure: just something to worry about
- battery voltage: came with one of the gauges. Never look at it
- SC cooling water temperature: no use whatsoever
- AFR: like watching a random number generator that's stuck between 14.4 and 15.0. Never used the actual gauge
On track I'm too busy to watch any gauges. I think a shift light would be helpful. On track anything that indicates temperature is just alarming until you get used to it.
#9 slindborg
Posted 27 April 2016 - 07:17 PM
Worry gauges, fcuk em
#10 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 27 April 2016 - 07:52 PM
Inlet temps, boost, oil temps, battery, afr so far. Will be fitting oil pressure soon. What would you guys say normal operating temps for oil is and what is classed as high? It seems to sit around 60 degrees when motorway driving?
#11 hairy
hairy
    Moonlander
  • 6,066 posts
Posted 27 April 2016 - 08:08 PM
rain gauge ... so I know when to put the roof back on
Edited by hairy, 27 April 2016 - 08:09 PM.
#12 Baron Von Scubadaddy
  • 6,645 posts
Posted 27 April 2016 - 08:44 PM
Depth gauge...
#13 furtive
furtive
  • 1,134 posts
Posted 27 April 2016 - 09:54 PM
OO gauge
#14 KurtVerbose
KurtVerbose
    His Serene Highness
  • 3,863 posts
  • Interests:Big baps.
Posted 27 April 2016 - 10:37 PM
Funometer, although it's installed on the drivers seat - not on the dash. :)
Also a rattlemeter in the same place. :(
#15 ufods
ufods
  • 235 posts
Posted 28 April 2016 - 05:18 AM
do you have no engine "blackouts" by reading the data via the obd port?
I have a PLX Devieces OBD Multigauge - but when connected to the obd port the engine have these little "blackouts" every 10 minutes.
#16 smiley
Posted 28 April 2016 - 07:42 AM
No, i've been running torque like that using a bluetooth adaptor for over a year.
No a single hickup. (that was with 2 active values. Will add Kpa on the next trackday in may)
Edited by smiley, 28 April 2016 - 07:44 AM.
#17 NOSBandit
NOSBandit
  • 271 posts
Posted 28 April 2016 - 07:32 PM
I have a egt gauge, with a warning lamp on the dash.
#18 ufods
ufods
  • 235 posts
Posted 29 April 2016 - 11:26 AM
No, i've been running torque like that using a bluetooth adaptor for over a year. No a single hickup. (that was with 2 active values. Will add Kpa on the next trackday in may)
Seems like i have to look for an andriod phone. These Hicups are not good when driving hard. Does boost pressure work on your torque app? On my plx gauge it does not work.
#19 stu8v
stu8v
  • 745 posts
Posted 29 April 2016 - 11:38 AM
I find update is too slow for any meaningful results when on the fly.
#20 smiley
Posted 29 April 2016 - 12:07 PM
These Hicups are not good when driving hard. I know. I get them using obdtuner when logging. Never with torque though. Does boost pressure work on your torque app? On my plx gauge it does not work.
I get the hickups when running obdtuner logging.
Not with the torque app though.
Will try the boost values this weekend.
edit; we seem to have had this discussion before:
http://www.vx220.org...ner-multi-gauge
And from the responses it seems that on a turbo car the boost cannot be read from the ecu.
Edited by smiley, 29 April 2016 - 12:14 PM.
